Old July 22nd, 2008   #1 (permalink)
Default Target Light?
Guys
How to make a target light using Maxwell?
I'm currently modeling on 3d Max.
Thanx
spuntik57 is offline
Old July 24th, 2008   #2 (permalink)
Maxer's Avatar
Default Re: Target Light?
Lights are created using materials, simply apply a material to an object that would normally be emitting light and there you go.
“There is no spoon”
Maxer is offline
Old July 24th, 2008   #3 (permalink)
I made the attached with a small sphere with an emitter material applied. Backed the sphere up with a parabolic reflector (quick hand made shape point to point (0,0 1,1 2,4 3,9 4,16) lathed scaled until "pretty") with an applied reflection material, maybe the default chrome. The sixteen different instances are merely moving the reflector back. Upper right is close then moves back by equal increments in reading order (left to right top row, down to left second row...).
(Guessing now...) To make a target light out of it, you could bind the "bulb" to the reflector. Put the reflector's pivot in the middle of the bulb. Create a dummy "light target" and assign a look at controller to the reflector to look at the dummy.
Peter M. Gruhn is offline
Vray Light Material quality aflack VRay Render 3 July 23rd, 2007 11:28 AM
Raw Light g-buffer question Gus_Rayvus VRay Render 0 August 25th, 2006 05:25 PM
vray light hotspot problem! please help ant_sutton VRay Render 4 August 24th, 2005 12:10 PM
How to render indirect light only Peppi 3ds Max 3 July 12th, 2004 02:33 PM
3dviz volume light beams through glass? chadsmith Autodesk VIZ 2 January 26th, 2003 07:32 PM
