Name: Jan Gall |
Hi all,
I have a spare Tyan Tempest i5400XT motherboard and instead of selling it I was wondering about the options for creating a dedicated render machine. I am working from a fairly small home office and for this reason noise and space may be an issue. The 1U rackmount cases seem to have a large footprint and im guessing they are fairly noisy? Im also concerned about cooling a case like this, I presume they are meant to be in a rack with external cooling so I cant just put it in a cabinet. Also wanted to know about operating systems for a server. Can i send renders from a 64 bit machine to a server that was running windows xp for example. I am probably not going to go over four gigs of RAM for the server machine so would I need a 64bit OS otherwise? Do I need much RAM in a render machine? Any help is very much appreciated!! Cheers! Last edited by Gander0; 3 Weeks Ago at 09:41 PM. |
Why a rack? It's only one computer. Just get some EATX case. You'll need the Xeon chips for it, at least 4GB or FBDIMM memory (more is an option with 64-bit Windows) and the rest of the computer, of course. If it's just a render node and you have another computer for the workstation, it doesn't need a good video card. It does need a good power supply.
Name: Shane Neal |
Go here http://www.tyan.com/product_board_detail.aspx?pid=562 and it'll give you all the info you need about compatible hardware and software
Name: Jan Gall |
Many thanks for your replies! AJLynn, looks like I will just get another EATX case then.
What do you think about the operating system? I am using vista ultimate on my workstation but I have a copy of XP pro (not 64bit) from a previous machine and was wondering if i could use this on the render machine without any OS compatibilty issues?(obviously won't be able to go over 4GB Ram.) |
Name: Jan Gall |
Ok, many thanks for your replies!
Just seemed a bit steep to have to buy another vista ultimate for a machine that isn't doing aught but rendering. I guess im gonna have to deal with it if i take this course of action Cheers |
When I got my computer a few months ago, the shop knew Ihaw I hated Vista but sold me a copy of Vista CorpCorporate (or something like that) - which gives me XP64 as well as Vista so I have an 'easy' upgrade path. Might want to consider it. It was only a f ew dollars more and he absorbed the cost difference in the system price.
| Maxwell Render 1.5 | Maxer | Maxwell Render | 205 | August 4th, 2007 12:59 PM |
| Weird Render Error?? | AFK_Matrix | 3ds Max | 2 | May 9th, 2007 03:34 AM |
| request to criticise the work | anindia | Work in Progress (WIP) | 4 | April 5th, 2006 01:47 AM |
| Cheap render machine | Garry Clarke | Hardware and Technical Discusions | 6 | December 21st, 2004 01:09 AM |
| Render Elements Crash | lebbeus | 3ds Max | 0 | December 5th, 2004 09:51 AM |
