Old July 24th, 2008   #1 (permalink)
vizwhiz's Avatar
Default does size matter?
check out The size of This ... er monitor
http://local.wasp.uwa.edu.au/~pbourk...on/UnityiDome/
its BIG and ROUND, must be nice
excerpt below
Unity and the iDome
Written by Paul Bourke
June 2008
Example 1
It is relatively easy to argue that there should be a gaming advantage if, like in real life, our peripheral vision is engaged. Not only does this give us a heightened sense of "being there" but it also engages our strong motion cues in a peripheral region. In the same way as we evolved to have a wide peripheral vision to help us detect predators, this peripheral vision can assist in early detection of dangers in a FPS game. The iDome allows one to play with our full peripheral vision engaged, both horizontally and vertically.
In order to demonstrate the use of Unity within the iDome, the standard demo that comes with Unity Pro is modified to support the warped fisheye images required for the iDome. The technique can of course be applied to any Unity based application.
vizwhiz is offline
Old July 24th, 2008   #2 (permalink)
Default Re: does size matter?
That's cool but it does not compare to the (9) across x (5) down 30" widescreen Dell LCD set-up they have at the Texas Advanced Computing Center.
http://www.tacc.utexas.edu/resources/vislab/#comp
Slinger is offline
Old July 24th, 2008   #3 (permalink)
Ky Lane's Avatar
Thats way cool..
However, looking through that site... cheeck out this..
http://local.wasp.uwa.edu.au/~pbourk...bition/witilt/
I want one! Imagine rotating around max with that in your hand, just spinning it around it mid air!?
Ky Lane is offline
Old July 24th, 2008   #4 (permalink)
Claudio Branch's Avatar
Originally Posted by Ky Lane View Post
check out this...
or this...
Claudio Branch is online now
Old July 24th, 2008   #5 (permalink)
shaneis's Avatar
Or this... 256 GFLOPS for $20,000!
http://www.techwarelabs.com/articles.../index_2.shtml
shaneis is offline
Old July 24th, 2008   #6 (permalink)
Ky Lane's Avatar
Originally Posted by shaneis View Post
How about 504 FlipFlops for $1,000?
http://cgi.ebay.com.au/Wholesale-Bul...QQcmdZViewItem
Ky Lane is offline
Old July 26th, 2008   #7 (permalink)
Originally Posted by Claudio Branch View Post
or this...
You may want to edit that photo and take out the license key
Slinger is offline
Old July 26th, 2008   #8 (permalink)
OK, let me break out the e-peen and beat you all:
Sun Constellation Linux Cluster
System Name: Ranger
Operating System: Linux
Number of Nodes: 3,936
Number of Processing Cores: 62,976
Total Memory: 123TB
Peak Performance: 504TFlops
Total Disk: 1.73PB (shared)
31.4TB (local)
I WIN!!!!!!!!!!!!!!!!
Slinger is offline
Old July 26th, 2008   #9 (permalink)
vizwhiz's Avatar
you win!! but at what cost???
vizwhiz is offline
Old July 26th, 2008   #10 (permalink)
shaneis's Avatar
U.S. Department of Energy’s Los Alamos National Laboratory Linux Cluster
System Name: Roadrunner
Number of Nodes: 3,060
Number of Processing Cores: 122,400
Total Memory: 98TB
Peak Performance: 1.026 PFlops
shaneis is offline
super res lcd's? D size sheets full size? 3dway Hardware and Technical Discusions 3 September 1st, 2007 11:44 AM
Does scale of model vs texture size matter? swenson 3ds Max 2 August 10th, 2007 11:22 PM
Image size and resolution blair Photoshop 4 May 24th, 2007 09:06 AM
bucket size frank1331 VRay Render 3 September 20th, 2005 10:02 AM
Which Size of Wacom Tablet?? Richard McCarthy Hardware and Technical Discusions 18 February 24th, 2005 09:48 PM
