Go Back   CGarchitect.com > 3D CAD SOFTWARE > Autodesk Revit
Autodesk Revit Autodesk Revit
Old July 28th, 2008   #1 (permalink)
Tim Nelson's Avatar
Default Exporting large models
Are there any Revit experts out there? I am receiving a very large fbx file from a company, about 240mb, and I'm not feeling confident that I'll be able to work with it very well in Max. It has been importing for quite a few minutes now.
Are there any good tips or options I could tell them to use when exporting the files to try to keep the file size & poly count down? I think they are only giving me the shell too & no interiors.
I really don't want to have to rebuild the model, so any help I could get would be appreciated.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old July 28th, 2008   #2 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Re: Exporting large models
Tim,
You might want to read this thread for tips.
http://www.chaosgroup.com/forums/vbu...revit+geometry
I am working with a FBX now. There are a few nice things about them, but they don't really appear to have solved the problem with heavy geometry and lagging viewports because of it.
travis schmiesing
Old July 28th, 2008   #3 (permalink)
Tim Nelson's Avatar
Would you recommend that I request a dwg instead, exported as solids?
Tim Nelson
timnelson3d.com
Old July 28th, 2008   #4 (permalink)
I don't have a solid answer for that. You may also want to try the free FBX converter from Autodesk. It will allow you to go to DXF but not DWG from FBX.
travis schmiesing
Old July 28th, 2008   #5 (permalink)
Justin Hunt's Avatar
I have found dwg's cleaner than fbx.
Both have their issues eg dwg have 10000's of blockheaders and fbx meshes the geometry too much.
Sometimes I explode the dwg in acad until it gets down to meshes and then import that. Seems to help get rid of the blocks. and you have more options on importing and how the meshes are handled
Maybe ask them to break the model up into logical bits and send you those instead
Either way it could be an headache.
jhv
Justin Hunt is offline
Old July 29th, 2008   #6 (permalink)
Chad Warner's Avatar
If you don't plan on using the revit (mental ray) materials that may or may not be applied to the model, I'd go with DWG. I find it a lot easier to strip all the junk out in ACAD and then bring it into max.
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Real models vs. virtual models oluv Realtime/VR/ Interactive/ VRML 1 November 7th, 2007 02:53 AM
Light fixture models with ies files, copyrights pailhead General Discussions 4 September 9th, 2007 06:35 PM
Best Pracitices - for large models RTurner VRay Render 13 August 3rd, 2007 03:25 PM
Hot fashion models - HELP!! smorehouse 3ds Max 10 June 14th, 2006 07:20 AM
Golf Resorts and Lands' very large models philip kelly General Discussions 7 October 23rd, 2004 03:35 AM
