#2 (permalink) | |
When you build your wall, make sure you select "UNCONECTED" from the options bar and that you specify a numerical height.
Name: William Lopez Campo |
Dave,
In plan View use the Pick tool to create the wall. The External Finish Face alignment will help you posifion the wall. Use Unconnected Height as Cesar R suggests, and use the Offset to specify the Overhang. Cheers, William. |
| Revit Architecture - Stacked Wall Problem | AFK_Matrix | Autodesk Revit | 8 | October 31st, 2007 12:38 PM |
| Rendering hotspots from spotlights on a wall? | THEPRAYINGMANTIS | VRay Render | 5 | July 18th, 2007 04:56 PM |
| how to create this curtain wall or wall | taylor77 | Autodesk Revit | 5 | March 24th, 2007 11:55 PM |
| Making Dormers on a Wall Object | Cookiepus | 3ds Max | 12 | November 20th, 2006 06:15 AM |
| Revit 6.1 | Cesar R | Autodesk Revit | 23 | December 17th, 2004 04:19 PM |
