Autodesk VIZ Autodesk VIZ
Old August 11th, 2008   #1 (permalink)
Default AVI Movie in VIZ
Hey guy's,
It's been a long time since I posted on here as I've been away for a few weeks (wohoo) now back at work!!!
My question is, can 3DS Viz allow for Avi movies (or any other movie format) to be inserted, so that when rendering the movie is called up and is played too?
All replies appreciated.
iaga is offline
Old August 11th, 2008   #2 (permalink)
STRAT's Avatar
Wales
Default Re: AVI Movie in VIZ
yes, you can incorporate AVI files into your materials so they play/render frame by frame in your animations.
STRAT is offline
Old August 11th, 2008   #3 (permalink)
Thanks for the swift response Stephen.
Now I'm going to pester you on how this is done step by step if possible, please....
iaga is offline
Old August 11th, 2008   #4 (permalink)
STRAT's Avatar
Wales
you'd be out of luck there i'm afraid friend, i dropped max years ago. i know it can be done but cant give you precise setup instructions.
STRAT is offline
Old August 11th, 2008   #5 (permalink)
Ok no worries mate - I'll just have to delve into the help files and see what I can find.
Once again thanks for you help. BTW if you'd dropped max, what are you using now? (just out of curiosity)
iaga is offline
Old August 11th, 2008   #6 (permalink)
STRAT's Avatar
Wales
cinema4d
STRAT is offline
Old August 11th, 2008   #7 (permalink)
Aha! after a little investigation of my own I have found how to do it.
It's as simple as applying a normal texture map by slecting bitmap and all you do is select the movie file.
How easy is that? When you know how!!!
Thanks for your help Stephen btw.
iaga is offline
Blurry QTVR movie jonrempel 3ds Max 5 December 17th, 2006 10:11 AM
attaching movie files.. NOOXY Cinema 4D 6 March 14th, 2006 10:32 AM
exporting just a part of a movie 3dsmaxed Compositing Software 7 August 9th, 2005 07:58 AM
Network render avi file DrunkenMonkey 3ds Max 7 March 4th, 2005 11:05 AM
Job Structure in Movie Industry Kal General Discussions 9 November 1st, 2002 11:18 AM
