Name: Thure Kjer |
At first I want to say hello,
I´m from Germany und my English is not as good as it could be. So I hope, you´ll forgive me my mistakes. I have a question. I build an objekt in Cinema 4D 10.5 and tried to texture it with maxwell-materials. But I´ve got some Problems with alphamaps. For example I want to put an different Logos on an rubber-texture. My plan was to overlay three textures. The ground(rubber)-material, than I want to put the logotexture witth a new Material over the groundmaterial. But when I start the Maxwell render it renders only the rubbermap. Has someone an idea, how I can do it? Thanks, Tomboml |
Name: Kurt S... |
It's very simple: Use weightmaps in the weightmap slot for each layer. You will need three layers, one for each kind of texture. The wheightmap must be a black/white map where the white parts define where the layer is visible.
With this method you can combine an infinite number of materials in Maxwell. KurtS |
Name: Thure Kjer |
In this way, I get one Material with a Layer for the ground-texture and another for the logo, is that right? But thats not what I want. I want to use different materials, so I can move the logo on different parts of the objekt.
Have a look on the objekt, I´m working with: (I send you a picture per mail, hope it works, because I´m not able to post a link.) There is a metalic button with a red line On the original you can see, there are some symbols on it. I jolted the metal-material to get the actual look. And now I need a new texture for symbols to lay it over the metal, but i won´t work. I don´t now what´s wrong. Generally I think its more comfortable if you can overlay different materials. |
#4 (permalink) | |
Name: Kurt S... |
If you want to move the logo around, then wheightmaps might not be the best way to work after all. I guess the easiest way to do this would be to duplicate the surface/element and move the copy just an infinit small distanse above the original. Then apply the logo to this copy using a ghost layer (invisible) for the part outside the logo. Use a weightmap for the logo and inverted for the ghostlayer. The ghostlayer is just a normal layer with attenuation= white and nd=1. It gets invisible. Now move or rotate the U/V for this element to move the logo around on the surface. |
| Tags |
| alpha, cinema 4d, maxwell render |
| Network Rendering Problems - Maxwell Render | simbeanie | Maxwell Render | 2 | January 3rd, 2008 05:12 AM |
| Maxwell Render 1.6 Out Now | Jeff Mottle | CGA News | 0 | December 4th, 2007 12:50 AM |
| Maxwell Render 1.5 | Maxer | Maxwell Render | 205 | August 4th, 2007 01:59 PM |
| Maxwell Render 1.1 OSX Universal Binary Edition | Jeff Mottle | CGA News | 0 | October 23rd, 2006 12:00 AM |
| Maxwell, Vray, C4D, Final Render Comparison | mbr | Other 3rd Party Renderers | 4 | December 1st, 2004 02:03 AM |
