Cinema 4D Cinema 4D
Old August 18th, 2008   #1 (permalink)
Default Cutting Through A Model?
hi guys, ive been asked to do a 3d image of a section through a house model, is there a way of making the camera cut through the scene without distorting the camera.....
Any advice would be much appreciated.... regards dan
DAN212222 is offline
Old August 18th, 2008   #2 (permalink)
Name: Andrei Stefanescu
Romania
Default Re: Cutting Through A Model?
you can use camera clipping planesif you want to make the section paralel to the camera view, or you can select the whole model and allpy a "slice" modifier, and a "cap holes" modifier, and play around with that.
good luck
andstef is offline
Old August 18th, 2008   #3 (permalink)
thanks for that....
im trying to do the camera clipping plane, but cant find a tutorial on how to do it .....
any ideas or any tips
dan
Old August 18th, 2008   #4 (permalink)
BillyElNino's Avatar
England
im getting laid off and selling my copy of cinema 4d
Still hanging in there then!
It depends on the level of detail you wish to attain. Some section processes will leave your mesh open at the section cut. You may want to consider physically cutting up your model with the knife tool and removing the excess, or even modelling in what would be revealed when the section is taken. You can use a boole object to obtain a section with the faces filled in or not.
BillyElNino is offline
Old August 18th, 2008   #5 (permalink)
Romania
Well, it's quite simple
place the camera in your scene and use the near clip value to cut where you want (the value is the distance from the camera to the clipping plane, anything closer to the camera will not be displayed)
andstef is offline
Old August 18th, 2008   #6 (permalink)
HMMMMM boole now theres an idea,
yeah just ticking over for the next couple of weeks, then have to look at new job.... bit crap up here in the north east no residential work at all.... im qualified as an architect technician who does 3d work too.... everyone seems to be getting laid off, so not much hope of finding another job in the industry for a while.... well until the credit crunch is finished.... lol
Old August 18th, 2008   #7 (permalink)
England
We'll be reminiscing about the good old days during the credit crunch when the recession kicks in properly!!
Old August 18th, 2008   #8 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
cliping planes very easy, in what i use at least
i was going to respond with use the Archcut plugin but your desires are different.
Antisthenes is offline
Old August 19th, 2008   #9 (permalink)
gdrakakis's Avatar
Greece  Send a message via Skype™ to gdrakakis
hi,
this is a simple xpresso set-up of parallel cameras.
it ties the DOF target distance with the near clipping.
this way you can set it precisely by moving the central orange handle of the camera
hth,
george
gdrakakis is offline
What is the best way in making 3d model in Architecture? juan General Discussions 41 June 11th, 2008 02:15 PM
How do YOU model your buildings? vismagine General Discussions 8 December 14th, 2007 03:50 PM
Change a editable spine into a model with skin Michael Earley 3ds Max 1 October 23rd, 2007 08:27 AM
$ / hour Jago_0108 General Discussions 19 March 7th, 2007 04:21 PM
Cutting off a model AJLynn 3ds Max 9 October 21st, 2005 08:26 AM
