Name: Tom Williams |
Hi can anyone help? I have imported a sphere from sketchup and when I render in cinema 4d the sphere appears to be made of a number of squares. The same happens if I produce the same model in archicad. I render in cinema 4d but can not model with this program hence why the sphere is made in sketchup. For a better understanding I have attached an image of the edited sphere to illustrate the problem.
If anyone can tell me how to correct this issue that would be great. Kind regards Tom |
Take the imported ball object and drop it into a hypernurbs object in C4D... drop meaning making the ball object a child in the hierarchy of the Hypernurbs. The parameters in teh hyper nurbs will allow you to smooth. May not work perfect, but there are always ways around imperfection
Have you optimised the model after import???
Do you have a phong tag on it??? Also you do not have enough facets in your model coming from Sketch up... Modelling this in c4d will take seconds though... just create a sphere up the segments in the attributes till you get a good round object... Make it editable(press C) loop select the loops you want to push in... (press ul) Then press d and click and drag on the screen somewhere.... not on the object though.... Regards Lee
www.buzzbox.eu |
Hey guys, thanks so much for your help and advice!!!!! I have just modelled it in c4d! Never modelled before. Can not believe how easy that was.
thanks again, i really do appreciate it. cheers Tom |
| Help with importing circular shapes from AutoCad to 3dsMax9 | Rfman35 | 3ds Max | 4 | July 7th, 2008 01:34 PM |
| Procedural Circular Paving | martin walker | 3ds Max | 6 | October 4th, 2006 03:07 PM |
| circular stair case | alikashan | 3ds Max | 2 | November 14th, 2005 10:28 AM |
| circular ramps and staircases | haneet khanna | AutoCAD/AutoCAD Architecture | 6 | May 15th, 2004 09:11 AM |
| Circular stair | Arkitec | Autodesk VIZ | 4 | April 29th, 2004 07:19 PM |
