| CGA News The Latest News Posted on CGarchitect.com |
#11 (permalink) |
Name: Justin Hunt |
Brian you got it right, as with everything it has to be set up properly to get true readings.
A similar discussion came up years ago with regards to solar studies. Basically the question asked was, "can I stand up in court and truthfully say that the solar study is accurate?". Basically the solar study was setup in two different packages with the same data. Each gave different results and each software developer said theirs was correct. When compared to varoiuse industry accredited solar study data sets, neither were correct. jhv |
#12 (permalink) | |
Name: Brian Bradley |
I am glad that I don't make my living doing any kind of serious analysis work like this as I can imagine that validating the accuracy of data can get to be a serious pain. For general light studies though I am glad that AD are incorporating these kind of tools into Max. Regards Bri
#13 (permalink) |
Name: PIerre-Felix Breton |
The difference between the IES Sun and mrSun is expected as both uses different internal mthods of estimating the intensity of the Sun.
The problem of daylight analysis is that there is no way to model a single sky condition.. so certain methods try to average it, other try to use the best case scenario (like a clear sky with pure atmosphere..). The good news is that with Lighting Analysis woorkflows, the important question is "ball park figures". We could not care less about a difference of 15% 20% betwen 2 measurements. Lighting has a lot more tolerences than what you think. Stay tuned, I'll post the link to the white paper once its public. You will find a lot of answers in it. P.S. Jeff, please fix the workflow of cutting links: I lost all my previous reply because of this :\: I got a warning, I pressed ok and all my text was lost... |
#14 (permalink) | ||
This is exactly what I would expect, but 2 different intesities for Sun objects clearly has potential to confuse. (not regarding light analysis because the MR Sun is the one specified to be used for this task). Quote:
Regards Bri
#15 (permalink) | |
Since its alway very difficult to retire functionnality from a product for compatibility reasons (you'll always have someone who complain that a certain button is critical to their business...), we have to keep them around for a little while. For your information, the IES Sun uses the maths of the IESNA RP-21 paper and the mrSun/mrSky for analysis uses either the CIE Sky or the Perez All Weather sky model. They all have different usage so they have different internal algorithms. |
#16 (permalink) | |
Thanks for the continuing heads up on these systems and be sure to post up the white paper link ASAP. regards Bri
#17 (permalink) |
Name: Elliot Correa |
Pierre
Wao... I hundred years since I heard from you..... Very seldom I write notes on this forum, I just read the threads all the time. I am sorry to use the forum to say Hello to my old professor. Your child must be ready for college by now......! Our where not born when I met you and now they are 11 years old.... Nice to see you are around. I still go to Montreal once a month and still debating if I should move there. We all want to move but the business needs me here as well. Next time I go there I will call you.... I am going next week to Toronto and perhaps I will jump to Montreal. Nice to see an old friend... Hi hi hi Would you believe that from time to time I use Lightscape....! I just sent a PO for the full blown version of Max... Now I am confused... should I change it to this new version. If you were involved in this new one, I know it has to be precise since you are a perfectionist. Regards Elliot Correa Atlanta, Georgia
Elliot Last edited by Elliot; August 30th, 2008 at 05:33 PM. Reason: grammar 2 |
| New Viz2008 to Max 2009 Design pricing | Trevor Tizard | General Discussions | 5 | April 3rd, 2008 01:47 PM |
| Autodesk 3ds Max 9 - 64bit | luckytohaveher | Hardware and Technical Discusions | 7 | August 6th, 2006 09:45 PM |
| 3ds MAX and W2K SP 4/Hot Fix Issues | Jeff Mottle | 3ds Max | 16 | October 10th, 2003 12:07 PM |
| Discreet 3ds max Extensions | easy | 3ds Max | 7 | December 16th, 2002 11:39 PM |
