| CGA News The Latest News Posted on CGarchitect.com |
President/Founder
With the release of Autodesk’s new 3ds Max Design 2009, the era of Autodesk Viz officially comes to a close. Positioned to take over the market that Viz filled, Max Design 2009 essentially replaces AutoDesk Viz for the Architectural Visualization market, while the original Max 2009 is still geared towards the traditional visual effects and entertainment industries.
Read More... |
#2 (permalink) | |
Name: Jim Buchanan |
Autodesk can charge more. The marketing department won out I would say whatever the spin. Well maybe people will vote with their feet and choose Cinema 4d and the Vray plugin. Am I cynical or what? |
#3 (permalink) | |
Name: travis schmiesing |
We wanted to see how the heat of the sun through a skylight was effected if we applied a frit material to the glass vs not applying a frit material to the glass. We sent the results to our lighting consultant to get feedback. The lighting consultant said that the numbers were way to high. We haven't touched it since then to see where things went wrong. The question I have... Does this only work with Pro-Materials? We are using Arch & Design. I thought Pro-Materials were simply stripped down Arch & Design materials with some customization, but I may be wrong.
travis schmiesing |
Name: Joel Callahan |
I used it in a classroom environment, well, just the light meter.
We used it to see the light levels as they fell across a floor. It was a quick-n-dirty way to 'see' how strong the light would be without actually having to sit through a render. |
#6 (permalink) | |
Name: PIerre-Felix Breton |
The results will be published soon, be we can say that we are as good as any other lighting analysis benchmarks that where validated out there. The trick is to get the right settings... so to help with this, we are currently writing a white paper on the topic to help you "get the numbers right". Regards, Pierre-Felix Breton Product Designer | Autodesk M&E Last edited by pfbreton; August 26th, 2008 at 07:22 PM. |
#7 (permalink) | |
travis schmiesing |
Name: Justin Hunt |
If you watch one of Brian Bradley video's where he covers the light analysis tools , he clearly demonstrates discrepancies in what is read out and what is known. As such I would not rely on its accuracy.
jhv |
#10 (permalink) | |
Name: Brian Bradley |
Hey Guys, To be fair to the discussion, the quick usage we made of the 'Light Meter' tool in our 'MR Toolbox' module that looked in depth at the MR Sun 'light type', couldn't really be described as anything like serious light analysis work! If I am on the same wave length as Justin (jump in and correct me if I am wrong my friend an IES sun type, but is corrected by setting the Sun colour to 'White', and as colour info needs to be kept out of such a sensitive process as 'Light Analysis' (this is why the MR Sky now has more than one atmospheric model to choose from), that result is not surprising. A clearer approach to an 'analysis' workflow would be very useful to Max users so a 'white paper' would be very welcome. I have etched out some rough procedures and ideas for a module, but some definitive info from the tools creators will help everyone use this tool to full advantage. One potential source of confusion though is the differing intensities between an IES sun and a MR Sun (80000 Lx & 92000 Lx) Which is something that is seen in our module!! Regards Bri
| New Viz2008 to Max 2009 Design pricing | Trevor Tizard | General Discussions | 5 | April 3rd, 2008 01:47 PM |
| Autodesk 3ds Max 9 - 64bit | luckytohaveher | Hardware and Technical Discusions | 7 | August 6th, 2006 09:45 PM |
| 3ds MAX and W2K SP 4/Hot Fix Issues | Jeff Mottle | 3ds Max | 16 | October 10th, 2003 12:07 PM |
| Discreet 3ds max Extensions | easy | 3ds Max | 7 | December 16th, 2002 11:39 PM |
