Old September 5th, 2008   #21 (permalink)
robert taylor's Avatar
Default Re: Night Apartment External..um.. Internal...
Amazing work,not really in a position to give my opinions as im still learning.What programes do you use to create those works??
robert taylor is offline
Old September 5th, 2008   #22 (permalink)
Ky Lane's Avatar
Originally Posted by shaneis View Post
AH, where would we be without the zapper? Was reading this moments before your post
Ky Lane is offline
Old September 5th, 2008   #23 (permalink)
Ky Lane's Avatar
MSpaint
Just the usual mate, 3ds and MR.
Ky Lane is offline
Old September 5th, 2008   #24 (permalink)
SandmanNinja's Avatar
Good point, Nic!
I'm trying that Split Render script out right now.
Ky - great scene. Very inspiring.
-SandmanNinja
website
SandmanNinja is offline
Old September 5th, 2008   #25 (permalink)
Ky Lane's Avatar
Originally Posted by nicnic View Post
make sure your texture res is going to hold up being rendered at that size!
I know its not, but... I cant help thinking... 300dpi.. thats like "in your hands looking like a photo" resolution. Something tells me, the client (a "traditional print agency" is being lazy and just asking for 300dpi when we all know 150 or even less will do.
Ky Lane is offline
Old September 5th, 2008   #26 (permalink)
nicnic's Avatar
yep, its always the case isnt it. I have used fractal enlarge pro previously to blow up images to this res when we knew the textures couldnt hold up at that res.
nicnic is offline
Old September 5th, 2008   #27 (permalink)
By the way, the Split Render script works GREAT! It makes it very conservative on the system resources and you just nudge them into their proper place in Photoshop. The output gets dumped into the My Documents\3dsmax\sceneassets\images folder.
Thanks for the script.
-SandmanNinja
website
Old September 7th, 2008   #28 (permalink)
Ky Lane's Avatar
Does it save the alpha channels too Joel?
Ky Lane is offline
Old September 7th, 2008   #29 (permalink)
Name: Fred Flintstone
Nice work Ky,
Do know is this for the Macrossan in Brisbane ? on Macrossan st ?
If so I did some Viz for these guys years ago of the exterior of the building.
For your alpha's you can use the script called Render mask, its really easy to use.
Or if you keen check out L-Pass manager, its nice, similar to XSI's pass system.
Spacelord is offline
Old September 7th, 2008   #30 (permalink)
Ky Lane's Avatar
Originally Posted by Invaderzim View Post
Nice work Ky,
Cheers mate - Yes it is. This is for the project marketing team moreso than the architects. Its going on a huge outdoor sign, should be interesting.
Thanks for the advice.
Ky Lane is offline
internal lighting ZFact Cinema 4D 9 November 27th, 2007 12:19 PM
External Storage.. mbowers General Discussions 2 July 6th, 2007 03:10 PM
Apartment Exterior Render (Night View) VIC Finished Work 6 November 2nd, 2006 06:38 PM
Problems with settings for external Vray scene alfienoakes VRay Render 6 October 6th, 2005 07:58 AM
Apartment Internal Wokka Work in Progress (WIP) 2 May 22nd, 2005 07:16 AM
