Cinema 4D Cinema 4D
Old September 3rd, 2008   #1 (permalink)
Default importing models into c4d
Hi all
I am new to cinema 4d and have been posting a few threads recently asking for advice and have had some great feed back.
With regards to importing 3d models into cinema 4d. I have downloaded from the c4d website the plugin to export archicad models however i am having a few problems once i open the model in c4d.
I am unable to orbit the model holding the key button '3'. I have the same problem with 3ds models from sketch up as well. Has anyone had this problem?
Regards
Tom
tom10 is offline
Old September 3rd, 2008   #2 (permalink)
jackb602's Avatar
Name: Jack Bransfield
Default Re: importing models into c4d
What happens when you try to orbit? Does your view change at all, or does it change in an unexpected way?
It may be that the axis of the objects is off in space somewhere. Try going here:
Edit > Preferences > Document > Camera Rotation
and selecting the Center or Camera options.
You can also select an object and go to Structure > Axis Center and use it to center the axis within the object. Orbiting should then work correctly with the camera in Object mode.
Jack
Built Light
jackb602 is online now
Old September 4th, 2008   #3 (permalink)
BillyElNino's Avatar
England
This was something I struggled with when I started with C4D. As stated above its the axis being miles away from the object. Remember that when you import a 3DS all the objects will have the same axis point and need to be adjusted to suit your model. Have a look at the scale you are working in too, although C4D is units based rather than cm or mm etc I find it easier to work in cm and scale any models coming in accordingly.
BillyElNino is offline
Old September 5th, 2008   #4 (permalink)
[FONT='Verdana','sans-serif']I altered the measurements to mm and this seems to work ok now. How do I go about applying materials to the model? Normally I just drop them onto an object however this does not seem to work with 3ds models. Do I need to add some type of tag??[/font]
[FONT='Verdana','sans-serif'] [/font]
[FONT='Verdana','sans-serif']Cheers[/font]
Tom
tom10 is offline
Real models vs. virtual models oluv Realtime/VR/ Interactive/ VRML 1 November 7th, 2007 02:53 AM
Importing from 3dsmax into C4D? sezbod Cinema 4D 6 April 13th, 2007 10:51 AM
Importing CAD models into 3ds Max 7 bover 3ds Max 1 October 10th, 2005 10:51 PM
Importing Xfrog models Tim Nelson Autodesk VIZ 2 April 1st, 2005 08:06 PM
importing plans in c4d? DAN212222 Cinema 4D 5 March 29th, 2005 11:16 AM
