Old September 8th, 2008   #1 (permalink)
renderhaus's Avatar
Default Trouble Rendering Fire
How is fire rendered with Mental Ray? With Scanline rendering, it's pretty simple. Set up a gizmo, assign fire to it and adjust settings to taste. But Mental Ray will not render fire via a gizmo.
So how is fire rendered with Mental Ray?
Thanks a ton.
renderhaus is offline
Old September 8th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: Trouble Rendering Fire
Deconstructing the Elements has Fire, Lava, Smoke, Water, Tornadoes, explosions - you name it.
I've only read through it, but I want to really work through all the exercises.
-SandmanNinja
website
SandmanNinja is offline
Old September 8th, 2008   #3 (permalink)
Brian Bradley's Avatar
All done using the Scanline though!!
Bri
www.mentalboutmax.co.uk
The MBM Blog
Vray Learning Resource
www.vrayelite.com
Brian Bradley is offline
Old September 8th, 2008   #4 (permalink)
renderhaus's Avatar
Bri
Really??? DANG!
There HAS to be a way to render effects with MR. This just makes no sense at all. I haven't used scanline in over 4 years! ...And I'm not about to go back to it either.
Old September 8th, 2008   #5 (permalink)
renderhaus's Avatar
SNAP! I got it to work!
At least, it'w working in an isolated scene - all by itself. I'll see what happens once I merge it into the scene where I couldn't get it to work before (with Daylight System active). I'm thinking that perhaps the MR Sky as an Environment Map might be what caused the fire effect not to work everytime I tried it before. If so, I'll just turn it off and go from there.
Old September 8th, 2008   #6 (permalink)
Hi Michael,
With a daylight system in the scene and exposure set up for
it you will NOT be able to see the effect of your fire! Just
as you wouldn't see any illumintion from a small hand torch if
you shone its beam onto a patch of Bright sunlight!!
regards
Bri
The MBM Blog
www.vrayelite.com
Old September 8th, 2008   #7 (permalink)
Bri
Actually, I leapt before I looked there!
I have only seen the original copy which used Max 6 and the
scanline engine, not sure if any of the effects were updated
for MR in the newer version!!
Regards
Bri
The MBM Blog
www.vrayelite.com
Old September 8th, 2008   #8 (permalink)
renderhaus's Avatar
Hi Michael,
regards
Bri
The fire is in a fireplace within a room. The nearest window is about 25' away and buffered by a wall. No direct light is entering the scene. In fact, very little (if any) indirect light is entering this particular scene. therefore I could elliminate the daylight system without any impact on my scene. It was being used primarily for the room with the window that this space in adjoining.
Old September 8th, 2008   #9 (permalink)
Might be worth disabling both it and the exposure (assuming you
have it) and doing a test?
Regards
Bri
The MBM Blog
www.vrayelite.com
Old September 8th, 2008   #10 (permalink)
renderhaus's Avatar
I've disabled EC & the Environment Map (MR Physical Sky). Now all I get is a black flame. Even when I change the smoke color, the entire flame remains black.
Rendering Elements without rendering complete frame tonina 3ds Max Wish List 3 October 5th, 2008 11:22 AM
V-Ray Version 1.5 Officially Released! Jeff Mottle CGA News 1 August 9th, 2007 05:48 AM
Cooperative rendering update Maxer Maxwell Render 15 June 19th, 2006 07:47 AM
vray rendering animation with backburner keeps rendering 1st frame d7man2000 VRay Render 3 February 21st, 2006 02:02 PM
PURE P1800 Rendering Card Jeff Mottle General Discussions 6 September 18th, 2003 03:11 AM
