Go Back   CGarchitect.com > 3D SOFTWARE > Maya
Maya Alias
Old September 22nd, 2008   #1 (permalink)
Malta
Default autocad to maya
When exporting from autocad what format allows for textures files to be included in the conversion so that the file can be used in maya?
Any help would be appreciated.
Thanks UMare
umare is offline
Old September 22nd, 2008   #2 (permalink)
toxic_box's Avatar
Iraq  Send a message via MSN to toxic_box Send a message via Yahoo to toxic_box
Default Re: autocad to maya
Hello umare
Till now no Good Format for Translating...you sould use Autodesk Direct Connect . to Connect DWG Files t maya......Maya will import the DWG as A Bunch of NURBS Surfaces...No Textures and Materials....This is the worst thing if you plan to Make an ArchViz with in maya....you have to Remodel in maya....will be much better.
So If you need to Visualise an AutoCAD or Revit Project...MAX is Recomended!
Cheers
/Tai
toxic_box is offline
Old September 23rd, 2008   #3 (permalink)
Malta
Thumbs up Re: autocad to maya
Thanks Tai, your reply was very helpful indeed.
UMare
umare is offline
Old September 23rd, 2008   #4 (permalink)
I find that using sketchup as a bridge between autocad / revit to maya gives me the best results so far. DWG to sketchup, then FBX to maya will convert much cleaner geometry. Plus any blocks will be converted to components in sketchup which will be converted to instance copies in maya.
If you don't have sketchup you can always use the old 3ds to maya with the bonus tools 3ds import but i find it takes a lot more clean up that the latter method.
Karlfucious is offline
Old September 23rd, 2008   #5 (permalink)
shaneis's Avatar
Blender http://www.blender.org/ is a great program for bridging between CAD and Maya as well... and it is completely free. Same workflow as Karlfucious mentioned CAD DXF > Blender FBX or OBJ > Maya. It is also good for the .3ds and .max imports.
shaneis is offline
Old September 23rd, 2008   #6 (permalink)
Antisthenes's Avatar
Name: Jonas Callewaert
Belgium
Rhinoceros works as a good "bridge" too
Antisthenes is offline
Old September 23rd, 2008   #7 (permalink)
shaneis's Avatar
Hmm...
SketchUp Pro - Win XP/ Vista, Mac OSX - US$495,
Rhino - Win XP, Vista - US$995
Blender - Win XP/ Vista, Mac OSX, Linux - US$0.00
That, my friend is what we refer to as a "no-brainer".
shaneis is offline
Old September 24th, 2008   #8 (permalink)
Belgium
995? naaa free for 25 saves or 140 for commercial licenses for students
Old September 24th, 2008   #9 (permalink)
I can't really comment on how well blender translates the files over since I've never used it but Sketchup converts over really clean geometry. Instead of importing a bunch of garbled triangles it tries to keep planar faces as ngons where possible. The only places it triangulates the mesh is where holes occur. That makes cleanup a much easier process and saves a lot of time. Also, all the face normals are in the correct direction.
Another plus of using the sketch up method as mentioned before is the fact that blocks/families convert to instance copies in Maya. So If you need to further detail a window you can model on one and the changes will carry over to each identical window.
With all that said there is no perfect translation. Sketch up is just the best I've found so far. Not only that Sketchup is a very handy little tool that I find invaluable to my pipeline.
Old September 24th, 2008   #10 (permalink)
shaneis's Avatar
Thanks for the info Karl. Tri's and normals are an issue. You can achieve similar results with Blender, though it isn't as simple as one or two clicks. Might just have to look into SketchUp.
Blender - free for unlimited saves, forever, for everyone...
shaneis is offline
Anyone else model in AutoCAD? Anyone use file linking? Reitveld AutoCAD/AutoCAD Architecture 44 September 27th, 2008 05:59 PM
AutoCAD 2d to 3d Max Architectural Renders Odunayo General Discussions 4 June 27th, 2006 03:54 PM
Autocad to Maya nightmare LunaCyborg Maya 0 March 18th, 2005 02:58 PM
AutoCad to Maya himark Maya 5 March 11th, 2004 07:51 AM
Render in AutoCad P.R.S. Sivakumar General Discussions 13 September 11th, 2003 05:33 AM
