Cinema 4D Cinema 4D
Old September 23rd, 2008   #1 (permalink)
Name: ivan agustin pedraza peluffo
Colombia
Default Units in cinema
I have seen that when i create a cube in cinema it appear by default 200m, but it does not seem as big as 200 meters in real size. So my question is, what measure to use to create a real wall or a column for architectural purpose?
mangalore is offline
Old September 23rd, 2008   #2 (permalink)
AJLynn's Avatar
Default Re: Units in cinema
If you changed the default unit to inches your default box would be 200 inches. The size it tells you is th real size, and it's used sometimes like with certain renderers.
AJLynn is offline
SIGGRAPH 2008 - Maxon Delivers Fully-loaded Cinema 4d R11 Jeff Mottle Press Releases 0 August 12th, 2008 09:51 AM
convert units when merging files. nazcaLine General Discussions 11 January 11th, 2008 08:30 AM
system units inch_drawing units cm maxs 3ds Max 6 November 14th, 2007 04:49 AM
finalRender Stage-2 SP3 for CINEMA 4D Release! candicekulacz finalRender 0 August 8th, 2007 08:36 AM
have the problem with install archicad to cinema 4d exchange plugin. Jagoda Archicad 1 March 8th, 2006 05:51 PM
