#11 (permalink) |
Not sure of the name of the one we use. Ill let you know once Im in the studio.
However, have a look at this : http://www.cs.ubc.ca/~mbrown/autostitch/autostitch.html |
#15 (permalink) |
Name: Joel Callahan |
I've been doing pan photography for YEARS - over a decade - and all pans start life as a still image. Unless you do video...
So, output it as something lossless - tiff, bmp, png, etc do whatever you need to do to it - sharpen, resize, etc Convert it to a quicktime You can do this internal to 3ds if you have a 32-bit version of 3ds. Just go to the panoexporter, LOAD a pan, then export as a quicktime. I use PanoCube software because I'm on 64-bit |
| panorama exporter help | tri-cross | 3ds Max | 6 | September 13th, 2006 12:14 AM |
| Exterior Panorama | John Martin | 3ds Max | 0 | July 5th, 2006 02:12 PM |
| Quicktime panorama exporter question | Ged Trias | Autodesk VIZ | 8 | April 9th, 2004 12:35 PM |
| Panorama tour builder for max/viz | seismograph | Scripts | 3 | October 10th, 2003 04:20 AM |
| Inverse VR Panorama? | MegaPixel | 3ds Max | 1 | July 14th, 2003 06:21 AM |
