3ds Max Autodesk 3ds Max
Old October 6th, 2008   #1 (permalink)
Default Sharpening a Panorama
Guys i very often render out still images and then add a sharpen filter in post because ican never get my default render crisp enough.
if i wish to arender out a panorama, using the panorama exporter, then how would i add a sharpen filter to the panorama???
is it possible
daveb867 is offline
Old October 6th, 2008   #2 (permalink)
SandmanNinja's Avatar
Default Re: Sharpening a Panorama
I always add a touch of sharpen filter to my photographic panoramas.
If any of my renders are too fuzzy, then I play with the AntiAlias setting.
-SandmanNinja
website
SandmanNinja is offline
Old October 6th, 2008   #3 (permalink)
i still feel tho that the anti alias settings and sample settings and filter settings in MR are not good enough when it comes to wanting a nice crisp render like the output you get from vray
so how would i sharpen a panorama (not a still image but the one from the panorama exporter in max) in post???
daveb867 is offline
Old October 6th, 2008   #4 (permalink)
The panorama exporter in Max writes a TIF or BMP or JPG.
So... I'd sharpen it in photoshop.
Filter -> Sharpen
-SandmanNinja
website
Old October 6th, 2008   #5 (permalink)
Out of interest, what filter and sampling settings are you using?
Macer is offline
Old October 6th, 2008   #6 (permalink)
filter - mitchell
min - 1
max - 64
spatial contrast set to 0.01 for RGBA
noise filtering - standard
jitter - enabled
FG, medium preset with rays per fg point adjusted to 300
anything else or am i way off with these settings???
daveb867 is offline
Old October 6th, 2008   #7 (permalink)
Ky Lane's Avatar
Render the image at twice the size you need, and then resize in PS. Itll be much sharper.
Ky Lane is offline
Old October 6th, 2008   #8 (permalink)
cheers for the input ky, but that kinda defeats the point of sharpening in post, render time at twice the size vs quick smart sharpen in photoshop
and i'm not really after sharpening an image, but more the output from the panorama exporter, you know the 3d 360 degree virtual tour type thing
daveb867 is offline
Old October 6th, 2008   #9 (permalink)
Ky Lane's Avatar
*shrug* its what I do. Render the pano out as individual files and use some program we have to stitch it together and perform the pano result. Always comes out nice and sharp.
Ky Lane is offline
Old October 6th, 2008   #10 (permalink)
each to their own i guess
do you know what program i could use for the stitching process then ky??
daveb867 is offline
panorama exporter help tri-cross 3ds Max 6 September 13th, 2006 12:14 AM
Exterior Panorama John Martin 3ds Max 0 July 5th, 2006 02:12 PM
Quicktime panorama exporter question Ged Trias Autodesk VIZ 8 April 9th, 2004 12:35 PM
Panorama tour builder for max/viz seismograph Scripts 3 October 10th, 2003 04:20 AM
Inverse VR Panorama? MegaPixel 3ds Max 1 July 14th, 2003 06:21 AM
