Name: Srdjan Repensek |
Hi all!
Few years ago when I started with 3D Visuals of architecture, I did it in 3DS Max exclusively. Just recentley, friend of mine told me that is much quicker modelling in Autocad, and importing as *.3DS file for applaying materials and light in max. So 2 months ago, I started learning Autocad. Now I am busy, with a house in Cad, and I came across some problems whitch I could solve in Max, but was struggling in Cad. For example, in Max you can edit solids, by selecting nodes, and moving them, in max you can easy restrict moving to a single plan, and stuff like that. I am sure most of you are using Cad form modeling and Max or LS for rendering, I would like to know your opinions on this metter, are you restricted in Cad compering to Max, or that is only me? And how much you are quicker modeling in Cad, oppose modelling in Max (if quicker)or this is only metter of some people get used to certein software. I know, bottom line is, all the tools are good, but some are different in certein areas. I would like to see your opinions. Regards Sergio!
We make a living by what we get, but we make a life by what we give! |
Name: Craig Ramsay |
Started out modeling in AutoCAD but Max is so much faster for modeling especially Max 5 with its new poly tools. Stick with Max
www.shakedigital.com |
Name: Stephen Leworthy |
i wont go into a long massive answer here but just to say you have to know the software.
it's what you feel at ease with and what you're used to. i use max and acad, but acad is much more accurate and faster for modelling than max is, which is what it was designed for. max is much better at organically shaped objects than acad, but drastically lack acad's complete accuracy and control. |
Name: Christian Miranda |
Hi Sergio,
Here go my 3 cents... Autocad can be incredibly fast for hard-surface modeling such as straight walls, windows, doors, floors and ceilings (the close polylines + extrude + booleans workflow is unbeatable. 3dsmax offers a more humanistic approach to modeling in which you have a higher degree of control over your models, its modifiers can be used on a non-destructive way and there are certain types of objects that you can´t produce using autocad (within an acceptable timeframe) such as natural looking curtains, cushions, sofas, bedspreads and free-form furniture. Also you have to consider that some Max native object types such as Nurbs surfaces and Lofts have implicit UVW coordinates which makes texturing a lot easier. I think the ideal workflow is cleaning-up drawings and closing polylines in Autocad, extruding, lathing, lofting, etc...in Max and producing all the furniture in Max as well. Sorry I ended-up writing too much... I hope it helps some. |
Brasilieros sao muito inteligente! (Brazilians are very inteligent) because I agree with Christian 100%. Several years ago when I first started working in 3D I was learning the process through autocad and kept thinking to myself that there had to be a better way. Then someone from the gaming industry showed me how they work using 3D studio R4 (not even max yet) and it was exactly what I wanted. I stress the "I" in that phrase because different people are more comfortable with different work flows. I have tried to go back to autocad (and even ADT) several times since then to see if modeling right there would work better for me and I still don't think it does.
Bottom line is I try to use programs strengths and limit thier weaknesses which is pretty much what Christian described.
"writing notes is quieter." |
Name: Sawyer Fischer |
I am with Strat. I use what I know. But honestly I hate Autocad. :ngeupset: I have been using it daily for so many years now & I think it is a poorly done program. I like max I like the ui and I like the way it thinks. I am better with cad than max so I do use it a lot but I would rather use max. For 3d autocad & max just can't be compaired. The work flow I have developed involves using a footprint (2d) of the bldg plan and a 2d elevation. These are done with cad and modified with cad. I take them and pop them out in max. It works really well for me.
And you may ask yourself What is that beautiful house? |
Ok, now here goes my 1 cent (I'm out of change, sorry!
6 years ago, I started modelling using AutoCAD. Then, a guy who worked with me asked me why I didn't do all that stuff with Max, since I was going to export it, anyway. The problem is that I had never thought about doing so, but when I did I found it tremendously easy! Not to mention the UVW mapping part... So, today I model ONLY in Max, no more CAD for me. And before that I was a DWG native speaker. I even tried to use ArchiCAD, but it turned out to be even slower, since I had to remodel lots of things that came out wrong and/or double. I think it's better if you can keep everything in only one software, but that's just my humble opinion. And Yes, brazilians are so inteligent Brian, do you speak portuguese or it's just your computer? :ebiggrin: [] Rick |
Name: Ricardo Kassner |
Rick... We are getting old!
When I was a Civil Engineering student I began to learn AutoCAD R10 for DOS about 9 years ago. About 2 years later, I was teaching AutoCAD for many students and professionals and I trying to model something simple in 3D Studio 4.0 for DOS. Oh! My God!!! I´m really getting old!!! :ebiggrin: So... of course! On that time, it was so easy to agree that AutoCAD was faster modelling software compare to 3D Studio. Nowadays I still using a CAD software (ADT) as Civil Engineer and Architect BUT for modelling an design visualization proposals there is NO DOUBT of 3D Studio MAX's powerful. Kassner. |
Thanks to all of you guys for those valuable comment, I am more concern about Max/Cad issue. I also think Max is bit more advanced.
But few things are better, much better in Cad (unless you guys got different approach)that is boolening, in max you have to (whend punching holes in the walls)substruct by selecting the wall, than, click boolen tool, click button "Pick Operand B", than click box whitch is going to be used to make a hole; repeat whole operation for each window opening. In Cad you instantly pick all objects to make holes in the wall at once, so operation is much shorter. Second thing sometimes, when I punch too many holes in the wall, I loose some faces on the wall, I guess, that must be something wrong with my computer(I think I got a bios problem). And very big difference is Cad files are much smaller, and computer is struggleing less when you model in Cad. When you importing *.DWG file in Max, that takes for ever. Any comments? Regards Sergio!
True Max's booleans are crap
I used to use autocad for modeling a lot but as I got more confident with max I used cad less and now not at all for modeling Craig
