3ds Max Autodesk 3ds Max
Old October 10th, 2008   #1 (permalink)
Maxer's Avatar
Default Missing Dll
I purchased some model off of Trubo Squid that were pre-rigged for animation. When I open them I get this missing DLL error apparently it’s a plugin used to create maps for the original models. I’ve replaced all the materials and saved out a new scene but when I open the new file it’s still looking for this plugin. Is there a way to remove it from the scene file since it’s no longer being used? The reason I’m asking is because I need to render this animation out on my farm and because the nodes are also looking for the plugin they won’t render.
“There is no spoon”
Maxer is offline
Old October 10th, 2008   #2 (permalink)
mattclinch's Avatar
England  Send a message via MSN to mattclinch
Default Re: Missing Dll
Have you tried merging the model into a fresh scene then saving it out again?
Matt Clinch
Arch Viz Artist @ Hayes Davidson
http://www.hayesdavidson.com
mattclinch is offline
Old October 10th, 2008   #3 (permalink)
Maxer's Avatar
Yea, as soon as I merge the scene in it gives me the missing Dll warning and when I open it I get the same thing.
“There is no spoon”
Maxer is offline
Old October 10th, 2008   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
I would assign a new material to the entire scene. Not just an over ride, but a new material. Does the error exist then?
If it does, then the reference to the DLL is not located in the materials, and you can begin to look elsewhere. If it does not give the error, then we know it is in the materials, so it is just a matter of isolating where the reference is.
I was having a lot of problems recently because defaults for Light were set to use Vray Shadows. None of the lights in my scene was set to Vray shadow, but the default was. I didn't have Vray installed, and it would give me an error message. The solution was to select the light, and simply move the default to a ray traced shadow.
What I am getting at is that one of Max's material options may have been set to default tot his plug-in when you were using the files from Turbo Squid. You probbaly need to identify what material type it was, and make sure the default are set properly.
I am attaching a jpeg to this post. The left portion shows what my default looked like when it was trying to load a Vray Shadow. The drop down box was empty. I simply set the drop down to use something that I did have installed by default, and that fixed the problem.
travis schmiesing
crazy homeless guy is offline
Old October 10th, 2008   #5 (permalink)
Maxer's Avatar
I figured out what the problem was, there was a UVW clear modifier in the modifier stack and for some reason although I had already replaced all the materials in the scene it was still holding onto the something that was looking for this plugin. I deleted it and it works fine now, thanks for responding.
“There is no spoon”
Maxer is offline
Missing DLL "vrender60.dlr" renderhaus 3ds Max 11 3 Weeks Ago 09:10 AM
How to get rid of missing dll? octopus 3ds Max 1 October 24th, 2007 06:12 AM
v-ray camera, sun and sky: missing dll andreg VRay Render 6 April 3rd, 2007 09:45 AM
Solved! - Missing dll: inknpaint.dlt - Ink 'n Paint Chris LeBlanc General Discussions 0 January 26th, 2006 08:51 AM
Missing DLL Dialog Box Arkitec Autodesk VIZ 4 July 15th, 2004 02:05 PM
