3ds Max Autodesk 3ds Max
Old October 10th, 2008   #1 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Default Edge Opacity / Center Transparency
Has anyone tried to use Ambient Occlusion in the opacity slot before? I am creating a handful of diagrammatic renderings. I want the shapes to have stylized look where they are more transparent at the center, and more opaque at the edges.
The attached image shows one of the series of diagrams I am working on. I want to take any of those shapes, and apply this look to it, where it is more opaque on the edges, and less opaque / transparent in the center area.
travis schmiesing
crazy homeless guy is offline
Old October 10th, 2008   #2 (permalink)
Default Re: Edge Opacity / Center Transparency
Actually, I don't think AO will work. Neither will Gradient Ramp.
travis schmiesing
Old October 10th, 2008   #3 (permalink)
Chad Warner's Avatar
Which renderer are you using? With vray you can use the vray dirt map and invert the normal on the material, which should work to your liking.
_____________
Chad Warner
www.bluelimestudio.com
Chad Warner is offline
Old October 10th, 2008   #4 (permalink)
Oh ya, I guess that would be important. I am using Mental Ray, so no go on Vray Dirt Map. Perhaps I can find a MR Dirt Shader though.
travis schmiesing
Old October 11th, 2008   #5 (permalink)
jucaro's Avatar
Name: Juan Carlos Rosalejos
Philippines  Send a message via Yahoo to jucaro
Why not use a falloff map? The effect you are trying to achieve is almost, if not the same as the method used in making X-Ray, and electron microscope imagery effect. Its a reversed falloff. Think of velvet?
MD8 Design Solutions
X3MFX Interactive Design Agency
DE MAX Design PTE LTD
jucaro is offline
Old October 11th, 2008   #6 (permalink)
shaneis's Avatar
There is this X-Ray shader for Max on highend3d...
http://www.highend3d.com/3dsmax/down...ader-3947.html
The author's notes say it's tested to Max vers 9, it might be worth trying out.
Here's the direct link to the author's website...
http://dl3d.free.fr/download_shaders.php
shaneis is offline
Old October 12th, 2008   #7 (permalink)
This sounded promising, it gave me no errors when Max loaded, but when I placed it in the material editor, it didn't work properly. As you can see from my attached jpeg, the middle of the sphere previews solid, and transparent as shown on David Lanier's website.
Also, when it rendered it was a charcoal color, and not the purple shade that is set as the default.
travis schmiesing
Old October 12th, 2008   #8 (permalink)
I tested the fall off method. It works great on non square objects, such as the sphere shown in the attached image, but it doesn't work well on the parallel and perpendicular surfaces. I assume this is because the fall off is the same across the entire surface.
When I chamfered the edges, it became more interesting, but not enough to pull off the look.
travis schmiesing
Old October 13th, 2008   #9 (permalink)
 Send a message via ICQ to MrCAD
Lets see if this kinda effect helps..I made a small scene in max 9..
Meher
Home Office Furniture 3D
3D NEWs
MrCAD is offline
Old October 13th, 2008   #10 (permalink)
jucaro's Avatar
perhaps this?
jucaro is offline
Layers of opacity cause wireframes Peter M. Gruhn 3ds Max 3 August 18th, 2008 10:20 AM
opacity map on plane jorisAR VRay Render 3 February 8th, 2008 10:20 AM
Common transparency in Maxwell mat okmijun Maxwell Render 16 February 14th, 2006 03:23 PM
matte/shadow with opacity map Chad Warner Autodesk VIZ 2 February 23rd, 2005 05:05 AM
How to reflect opacity? M_Jaco Autodesk VIZ 2 July 23rd, 2004 01:24 PM
