3ds Max Autodesk 3ds Max
Old August 15th, 2003   #1 (permalink)
United_States  Send a message via AIM to schmoron13 Send a message via Yahoo to schmoron13
Am I missing something about photometric lights? I'm doing my first remodeling job (redoing my mom's kitchen) and decided to try using photometric lights to simulate what it'll look like. I have about 16 photometric lights, and it's KILLING my rendering. It's taking about 11 minutes in 3ds max with only a base/generic material and that's using vray free with very low rradiance map set to very low (hsph subdivs 30, interp samples 10)
here's what the model looks like ("quick" rendering)...
what am I doing wrong with photometrics? :???:
Doron Serban
schmoron13 is offline
Old August 16th, 2003   #2 (permalink)
with your subdivs and interp samples comment - i am assuming that you are using VRAY.
in the vray forum, i asked a similar question. apparently, when using some IES files, it can considerably slow things down with vray, but with others it can work just fine. there doesn't seem to be any determination as to which are problematic and which aren't.
i had problems when using an IES file on a linear light.
proces2 is offline
Old August 17th, 2003   #3 (permalink)
thanks Proces2...glad to see I'm not totally incompetent in using lights
I put in normal lights and just faked the results...here's the current set of pics:
link
-doron
Doron Serban
Old November 14th, 2003   #4 (permalink)
I believe that for photometric lights you have to have a closed space, like a box with inverted normals. Also, you should mix them with nonphotometric lights...
Starr
starr is offline
