3ds Max Autodesk 3ds Max
Old May 11th, 2003   #1 (permalink)
Pakistan
Arrow
Hi all
I am working on a new project at office. While working with boolen i have a problem. its not giving the desired results.
When i do boolean more than two times on a single object, its start missing the interlinking faces.
How, i don't know. Any one who knows how to fix this?
http://www.risingdust.net/
mohsin_95 is offline
Old May 11th, 2003   #2 (permalink)
Craig Ramsay's Avatar
Probably better to post this problem under your specific software... I take it that you are using max or viz?
Max and viz really do have poor booleans so you are best to try and avoid using them at all costs. The example that you have shown could have easily been made from extruded splines for example.
If you really have to use booleans then take a look at the Power Booleans plugin, it works much better than max's booleans.
Craig
www.shakedigital.com
Craig Ramsay is offline
Old May 11th, 2003   #3 (permalink)
STRAT's Avatar
Wales
what exactly are you trying to boolean? that colourful image doesn't say anything and that sheet of black circles i dont understand.
STRAT is offline
Old May 11th, 2003   #4 (permalink)
bigcahunak's Avatar
Looks like he is trying to subtract the black cylinders from that green object, and the ones marked in red didn't subtact. However I have no idea what its got to do with the upper image, which looks nice nevertheless.
Craig, if I remeber correctly, mohsin is a MAX user, so you advice gets another vote here.
bigcahunak is offline
Old May 11th, 2003   #5 (permalink)
quizzy's Avatar
what you could is the folowing:
Make the green obeject a little denser (more polygons) and attach all the cylinders and then boolean.
but the simpliest way to do this is top draw a rectangle, draw circle splines and attach them aal, and extrude'm
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old May 11th, 2003   #6 (permalink)
Strat if you look at the circles that have been marked with green they have an inner edge where as the booleans that didn't work correctly are missing the inner edge. It would be easier to see if the object was thicker.
Craig
Old May 11th, 2003   #7 (permalink)
STRAT's Avatar
Wales
yeah, i see it now.
max/viz booleans aren't really that crap, you just need to know how to use them effectively/correctly.
insert a load more faces into that green flat bit, and also make object editable between each boolean.
STRAT is offline
Old May 12th, 2003   #8 (permalink)
Yeah I wouldn't say they are crap but beginners tend to find it difficult to get a grasp of.
They work better if you are cutting into a dense mesh then you can use the optimise modifier to reduce the amount of faces in the object. I found a tutorial on max booleans once... I will try and find it and post a link.
Craig
Old May 12th, 2003   #9 (permalink)
plastic's Avatar
Austria
boolean operation like this one (holes in a curved surface) don't work well with mesh objects.
max's booleans also are can't handle multiple operators very good (lots of holes).
the best way would be to do it with solids/nurbs. with autocad or rhino. or even archicad, in case of windows.
there are plugins for max for better booleans, power solids and power booleans, but i don't recommend them, since they are expensive and buggy.
Marc Lorenz
http://plugins.angstraum.at
My 3d gallery at Flickr
plastic is offline
Old May 12th, 2003   #10 (permalink)
Plastic have you had problems with power booleans? I have it installed and think it is fantastic, I hardly ever have problems with it :???:
Craig
