3ds Max Autodesk 3ds Max
Old November 11th, 2003   #1 (permalink)
South Africa
Angry
Hi guys,
I am trying to boolean 7 cylinder and 5 spheres from box object. Am I asking 3DS Max 5 too much?
Please if somebody can help me? I am quite behind because of that problem. BTW I am trying to model one very complicated sealing with dome and vaults.
Regards Sergio!
We make a living by what we get, but we make a life by what we give!
Sergio is offline
Old November 12th, 2003   #2 (permalink)
DelfoZ's Avatar
Mexico Send a message via ICQ to DelfoZ Send a message via MSN to DelfoZ
can u post a imagen before and after the boolean ?
tnx..
DelfoZ | DS
Citta Nouva
DelfoZ is offline
Old November 12th, 2003   #3 (permalink)
Sweden
hey Sergio!
If you have a chance to model the sealing in any other way - do it!
MAX booleans suck, (they have allways sucked)thats the sad fact.
(although I read somewhere that they have fixed them for r6, does anyone know?)
anyways... I find that MAX sometimes does a better boolean job if you attach all your subtraction-objects together. That way you only do ONE boolean instead of 12... It doesnt allways work, but since MAX Booleans arent very logical, its worth a try.
/K
skogskalle is offline
Old November 12th, 2003   #4 (permalink)
  Send a message via AIM to Archy@NJIT
Alright,
Yes unfortunatly Max 5 does not always deal with booleans in the best way. However they did cover for it in one way. If you boolean an object, then use the optimize command(can be found under modify). This will allow you an option control the number of faces of the object, as well as the Auto Edge option. Playing with these settings will allow you to avoid those jagged edges. YOu may need to optimize after every time you boolean. I know it doesnt seem like the most practical way to do things, but it actually helps a great deal.
Best of Luck
JM
image is in the eye of the beholder
Archy@NJIT is offline
Old November 12th, 2003   #5 (permalink)
MegaPixel's Avatar
Name: Super Dave Osborne
For what it's worth, MAX 6 seems to be rock solid with Booleans. I'm getting clean mesh results with no random faces.
MegaPixel is offline
Old November 12th, 2003   #6 (permalink)
Sweden
"For what it's worth, MAX 6 seems to be rock solid with Booleans"
sweet! too bad I cant afford r6... but its still good that they fixed it.
I like booleans, but in r4 (which I use) theres simply too much trouble using them.
Maybe they´ll release an update / bugfix for earlier max-versions too?? what do you think?
Old November 12th, 2003   #7 (permalink)
South Africa
Hi guys,
thanx for all replys!
Unfortunateli, max 6 is not any better for booleans, at least in my case.
There is an image, green marks are surrounding areas where boolean was successful.
Regards Sergio!
Sergio is offline
Old November 12th, 2003   #8 (permalink)
Sweden
mmmkuy...
are you sure you have actually lost your faces? maybe theyre just flipped?
increase the segments on your box... I think it helps if all the faces are about the same size, and you have some pretty small stuff on you subtraction-objects.
Old November 13th, 2003   #9 (permalink)
DelfoZ's Avatar
r u booloan 1 by 1 .. ?? ?
Fisrt do what SKOGSKALLE saw " anyways... I find that MAX sometimes does a better boolean job if you attach all your subtraction-objects together. That way you only do ONE boolean instead of 12... It doesnt allways work, but since MAX Booleans arent very logical, its worth a try."
Then do what SKOGSKALLE saw "increase the segments on your box"
i think that have to work...
DelfoZ | DS
Citta Nouva
DelfoZ is offline
Old November 13th, 2003   #10 (permalink)
recon's Avatar
From the looks of that picture, I'm guessing that the original objects were not completely closed, which can lead to problems.
Can you post a max file of the two objects before the boolean operation?
John Manning
www.jm3d.com
recon is offline
