Go Back   CGarchitect.com > 3D SOFTWARE > Maya
Maya Alias
Old September 28th, 2003   #1 (permalink)
Netherlands
I have quit al lot of experience with Maya and now I try to learn some more about Mental Ray in Maya 5.0.
Only one problem with texturing I can not fix, maybe someone knows a solution.
When I texture a wall with a Maya-shader (a lambert with a JPG attached to the color-node) the texture looks good as long as I don't repeat the texture.
I use the normal way of assinging the texture to the face and then use: texture>planar mapping.
As long as the texture does not repeat, it look perfect, but when I repeat by scaling the planar mapping it becomes black in the rendering.
I tried to achieve the same by scaling the texture in de 2Dplacementnode in the hypeshade. But then I get the same kind of result.
Chucky is offline
Old September 30th, 2003   #2 (permalink)
I'd say to get answers probably quicker go to www.cgtalk.com and down to the Maya forum.
Cgtalk has alot more active Maya users.
Andy is offline
Old October 10th, 2003   #3 (permalink)
Netherlands
Problem solved!
Mental Ray doesn't like it when I switch off the filtering.
Chucky is offline
