| Tips, Techniques and Frequently Asked Questions The most informative threads and more frequently asked forum questions. |
Name: Marc Lorenz |
this is a small tutorial how to change the color of RPC cars with 3dsmax and autodesk viz...
first you will need this free plugin: http://www.cuneytozdas.com/software/...rrect_v204.zip read more about it here: http://www.cuneytozdas.com/software/ it's a material plugin that allows to change the hue/saturation, brightness, color balance of any map in the material editor. it's a great tool, because there is no other way to change the hue of a map, for example. now, if you want to change the color of a RPC car, just load the RPC material into the material editor (with the 'pick material from object' eyedropper icon), and wrap the rpc bitmap into a new 'color correct' map. step by step for newbies: --- you should see a multi/sub-object material, with only 1 sub material. open the submaterial slot. (click on the button with the car name on it) you'll see a standard material with a rpc map in the diffuse color slot then. (blabla.rpc) now replace the RPC map with a new map: 'color correct'. a dialog will pop up, asking you to discard or keep the old map. choose 'keep the old map as sub map'(!!) --- now you can tweak the rpc map. to change the color of the car use the 'hue' and 'saturation' spinner. it reacts like the photoshop hue/saturation tool. works perfectly to change the color of cars, since cars have only one prominent tone usually. with people this technique won't work well, because it will also affect the skin color. that's it, have fun update: quick example...the original RPC color is blue. ![]() [ April 04, 2003, 05:58 AM: Message edited by: plastic ] |
Marvellous marc!
President/Founder
There is one problem with doing this however. Becuase the Hue control affects the entire bitmap if you have a red car with red tail lights they are also affected. IE. you get green tail lights if you chnage the hue to green.
Jeff Mottle CGarchitect.com |
Maybe this can be masked out in some way... Imho the creators of rpc have a job to finish
nisus
#9 (permalink) | |
President/Founder
Hey Nisus I spoke to the guys ay ArchVision about this and it's not simply a matter of just changing the color of a few maps. I think an undertaking of this nature is quite complex and would require the stop in development of other advancments as it is so difficult. Quote:
#10 (permalink) | |
If there is any criticism to be leveled on RPC its the low diversity of content. Obviously they are adding more all the time, but if they cannot see that there is a problem with putting all yellow VWs in a parking lot then there is, well, a problem. Also, there are times that you don't want such bright, colorful, entourage. ArchVision really needs to figure out how to allow some control of content. |
