Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old June 23rd, 2002   #11 (permalink)
Smile
Does It work with 3D Viz r4
Frank is offline
Old June 23rd, 2002   #12 (permalink)
quizzy's Avatar
Just try it, if it works it works, if its not working it doesn't work.. [img]Graemlin/biggrin2.gif[/img]
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 23rd, 2002   #13 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Tnx quizzy,
I've must have skipped it somehow... I'll give it a try
rgds
nisus
nisus is offline
Old June 23rd, 2002   #14 (permalink)
quizzy's Avatar
okay... somewhere it says something with cupping or so...
obj.modifiers[ "cupping" ].bendAxis = 0
something like this...
well MAX 3 doesn't know the .bendaxis command, it should be .axis so it should look like this in the script:
-- Add the first bend modifier
addModifier obj (Bend name:"cupping")
obj.modifiers[ "cupping" ].Axis = 0
obj.modifiers[ "cupping" ].Angle = 90
-- add the bend modifier
addModifier obj (Bend())
obj.modifiers[ #bend ].gizmo.pos += [ 0, -fLength/2., 0 ]
obj.modifiers[ #bend ].Axis = 1
obj.modifiers[ #bend ].direction = 90.
-- Add the material modifier
This should definitely solve your problems...
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 23rd, 2002   #15 (permalink)
quizzy's Avatar
Okay i've modified the script and it works now with 3d studio max 3.xxx Its true that max3 doesn't like attaching to empty meshes (numverts:0 numfaces:0) so I just said to the script to create 5 vertices, and that fixed the problem....I've put it on my script page....
quizzy's scripting page
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 24th, 2002   #16 (permalink)
nisus's Avatar
Belgium
Tnx quizzy,
I'll give it a try. I guess I missed you on the boards, but I was in a meeting. Back behind my desk now, so maybe we'll meet in a while...
rgds
nisus
nisus is offline
Old January 22nd, 2004   #17 (permalink)
Sweden
cant find the script on any of the linked websites... sounds great though. If anyone has it, I would appreciate if you could send it to my e-mail.
skogskalle@hotmail.com
thanks in advance!!!
/Kalle
skogskalle is offline
Old January 22nd, 2004   #18 (permalink)
quizzy's Avatar
http://tdp.nu/cgi-bin/plugsearch_r4.pl?search=makegrass
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old January 22nd, 2004   #19 (permalink)
Sweden
aah... I think I searched for it under "modeling"-scripts....
thanks quizzy!
Old June 20th, 2008   #20 (permalink)
Lithuania
Default Re: script: make grass
Originally Posted by nisus View Post
Hi quizzy,
Very nice script I think. Unfortunately, I am not able to run it (because I use max3.1?)
The scripts always stops at "update patchOfGrassObj"
Have you tried it in 3.1? What are your results?
rgds
nisus
why are you using old versions of max? what is your reasons? i am just curious
whori is offline
