Go Back   CGarchitect.com > 3D SOFTWARE > Scripts
Scripts Post and discuss architectural scripts or maxscripts here. This forum is for all software applications.
Old June 20th, 2002   #1 (permalink)
quizzy's Avatar
For 3D Studio MAX, a make grass script, excellent script by the way. Only disadvantages are: It's all geometry and it is a bit slow to generate the grass.
Check this link for download....
interface:
sample:
[ June 20, 2002, 06:43 AM: Message edited by: quizzy ]
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 20th, 2002   #2 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Hi quizzy,
Very nice script I think. Unfortunately, I am not able to run it (because I use max3.1?)
The scripts always stops at "update patchOfGrassObj"
Have you tried it in 3.1? What are your results?
rgds
nisus
nisus is offline
Old June 20th, 2002   #3 (permalink)
quizzy's Avatar
I only tried it in MAX4.26... and my result you can see above, the little picture of grass, just a quick test. I don't have more time just now to test it, cause i'm going to net render a scene and then go home...hehehe [img]Graemlin/biggrin2.gif[/img]
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old June 22nd, 2002   #4 (permalink)
TDP
TDP's Avatar
Sweden  Send a message via MSN to TDP
Updated: to 1.2
Ok.<BR>I found and fixed the problem with Max 3.x. Basically. Max 3.x doesn't like it if you have an empty mesh and you call attach to attach items to it.<BR> So.<BR>I modified the internal logic to handle that.<BR>I also included a new sample file which was readable by Max 3.x.
http://tdp.nu/index.shtml
_W_W_W_._T_D_P_._N_U_
TDP knows talent is everywhere. All night, Every day:
Work is pleasure,Wonder is research,Training is knowledge.
_ _ _ _____________________ _ _ _
Knowledge is power.Stay informed!|
TDP is offline
Old June 22nd, 2002   #5 (permalink)
nisus's Avatar
Belgium
lovely!
nisus is offline
Old June 22nd, 2002   #6 (permalink)
nisus's Avatar
Belgium
unfortunately I got anohter error...
the scripts stops at:
obj.modifiers[ "cupping" ].BendAxis = 0
rgds
nisus
nisus is offline
Old June 22nd, 2002   #7 (permalink)
TDP
TDP's Avatar
Nisus
could you please tell me more
when what & how
it accours?
TDP is offline
Old June 23rd, 2002   #8 (permalink)
nisus's Avatar
Belgium
Hi tdp,
I do things like were described in the helpfile:
I draw a plane (200x200, 4 segments)(surface), copy the plane (border), change the segments to 10 and add a noise modifier to the border.
I press the button 'border' to select the border, and do the same with surface. I don't touch any settings yet and hit the "make this rocket fly".
The script starts making a basic plane with a few modifier and stops. When I analyse the scene afterwards I got these three objects:
* border
* surface
* TempGrassBlade: this exist of a plane, a uvwmap modifier, a taper, and a bend modifier called 'cupping'
after this, the script pops up with the line obj.modifiers[ "cupping" ].BendAxis = 0 selected.
Hope this helps you out a bit
rgds
nisus
nisus is offline
Old June 23rd, 2002   #9 (permalink)
nisus's Avatar
Belgium
Hi tdp,
I forgot to mention that I don't see anything in the viewports anymore. I can 'see' objects when i hit 'H' (shortcut to the selection list) but that's it. I can't zoom anymore and all grids dissapear.
rgds
nisus
nisus is offline
Old June 23rd, 2002   #10 (permalink)
quizzy's Avatar
Hey nisus,
Try this: the border object must be a spline with a normal modifier onto it. the surface object can be a plane with a couple of modifiers..
This should work... (see picture above
mq
Michiel Quist
http://www.3idee.nl
quizzy is offline
