Old July 1st, 2004   #2 (permalink)
Chad Warner
Chad Warner's Avatar
Default Re: window opening off screen??
If you ever had dual monitors, the window could be opening on what used to be other monitor. Either way, open the max.ini file and look for headers that have "position" in the name, with numbers like 162,356 as the value. If you see any numbers that are larger than the resolution of your monitor, change it to a lower number.
-Chad
Chad Warner is offline   Reply With Quote
