Go Back   CGarchitect.com > CHALLENGES > The Unchallenge
The Unchallenge A forum for "unchallenges" where users can post models or an idea so that the group can work together to solve the problem, develop new techniques and share thoughts about a particular topic. Kind of like a challenge but without a deadline.
Old August 6th, 2003   #11 (permalink)
Tim Nelson's Avatar
The building and lighting are there, and correct too. Some of you might recognize the light ring technique by DelfoZ - works great by the way. The only thing thats missing is most of the materials, which is up to you guys to work on anyways. There are, of course, a couple of maps that do work if you have your standard viz maps on your c drive, like the paving & concrete.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old August 6th, 2003   #12 (permalink)
Changed the lighting to radiosity, changed a lot of the materials. I'm still not happy with the bushes. Changed the glass surfaces.
If the gamma is messed up. I'm currently having problems with my output gamma setup.
I have the same problem with doing the same work over and over again. This was a nice change.
-Ryan
Sorry, had to post the picture to my lame web page.
http://www.geocities.com/montanaredeye63/index.html
montanaredeye is offline
Old August 6th, 2003   #13 (permalink)
Name: Tony Richardson
Has anyone else tried opening the file?
I opened it in MAX 5 and no building. The only thing that shows up is the sign above where the door should be.
Tony is offline
Old August 6th, 2003   #14 (permalink)
Tim Nelson's Avatar
thats strange. i made it in viz 3, so i don't know what the compatibility issues are between the 2 progs.
Tim Nelson
timnelson3d.com
Old August 6th, 2003   #15 (permalink)
Are you referencing other drawings for parts of the model?
I don't know what the problem could be either. Oh well. I tried. Good luck with the job.
Tony is offline
Old August 6th, 2003   #16 (permalink)
Tim Nelson's Avatar
i was linking the geometry into acad, but I bound the files together before i posted it.
i also tried downloading it at my work computer and everything came thru ok. guess it must be something w/ max.
thanks for trying!
Tim Nelson
timnelson3d.com
Old August 7th, 2003   #17 (permalink)
mauarduz's Avatar
Bolivia Send a message via ICQ to mauarduz Send a message via MSN to mauarduz Send a message via Yahoo to mauarduz Send a message via Skype™ to mauarduz
havin some fun
this could go on forever,
here are 9 alternatives
yeah right !
mauarduz is offline
Old August 7th, 2003   #18 (permalink)
mauarduz's Avatar
here is the file, i think
yeah right !
mauarduz is offline
Old August 7th, 2003   #19 (permalink)
mauarduz's Avatar
ok final attempt
http://www.cgarchitect.com/forum/fil...l-webweb_1.jpg
yeah right !
mauarduz is offline
Old October 30th, 2003   #20 (permalink)
wda
wda's Avatar
Name: William Alexander
Timmatron,
Was messing around with vray. Played with your model for a couple of hours, mostly for settings. Added some stuff. Played with it in photoshop. Turned out ok.
Trying for a stoneboard / grainex exterior. The colors are fairly close, from memory.
http://www.cgarchitect.com/forum/fil...=timmitron.jpg
Do not know how beautiful it maybe but what the hey!
rgrds
WDA
wda is offline
