| The Unchallenge A forum for "unchallenges" where users can post models or an idea so that the group can work together to solve the problem, develop new techniques and share thoughts about a particular topic. Kind of like a challenge but without a deadline. |
LinkBack (1) | Thread Tools | Display Modes |
#281 (permalink) |
Name: jeff michael |
I just stumbled across this late yesterday. Here's my 3ds Viz 2006 & Mentalray entry:
PC Stats: Dual Intel Xeon 3.06Ghz CPU 2.00 GB RAM 128 MB NVIDIA Quadro FX 1100 Render Settings: GI = 500 Photons per Sample 10000 Photons per Light Global energy multiplier = 1.5 Decay = 2 Final Gather: samples = 1000, filter = 1, max/min radius = 18"/1" Specular Bloom = MR's "Glare" camera output shader Processing & Render time = 2:50 ![]() Here's the exact same render but with a glass sphere and some caustics. The render time went up to 14:34. ![]() Last edited by werre; September 16th, 2005 at 12:15 PM. |
#282 (permalink) |
Name: nuno faria |
hey all,
maxwell render... 1 - sample level 11 / 35 minutes / shutterspeed 90 ![]() 2 - sample level 14 / 2 hours / shuterspeed 90 ![]() 3 - sample level 14 / no more time spent / shutterspeed 40 ![]() 4 - sample level 14 / no more time spent / shutterspeed 80 / tone mapping - autorange ![]() best regards, nuno
.Best Regards .Nuno |
#283 (permalink) |
Name: Jorge Tiscareño |
Anybody still have this model in dwg, 3ds or in max format. If so can you guys post it here or email me.
"That you are here--that life exists, and identity; That the powerful play goes on, and you will contribute a verse." Walt Whitman |
#284 (permalink) | |
Here is my old post with my version of the model in DXF: I decided to take a try at a highly optomized version of the basic model posted for these tests. I rebuilt the model on a strict module. Almost every polygon in this model is .5 meters x .5 meters, with a small number at .5x.25m The model is metric and in DXF format, NO triangles. No real-world model would be so optomized, of course. For consistency's sake, I suggest anyone using the new model render a view from: camera x, 1 y, -5 z, 1.4 target x, 3 y, 10 z, 1.4 view angle 76 degrees rendered to 720x486 sun is still at 346/23 (or 194/23 for Lightscape) Because the proportions changed a bit when I re-did this, the light hits at different points, but I like it because it hits all on a wall so most of the light on the floor is bounced. The original model was posted in post #2 http://www.cgarchitect.com/vb/34356-post2.html and I just checked it, the links still work. Last edited by Ernest Burden; August 23rd, 2006 at 12:14 PM. |
#285 (permalink) | |
Name: nuno faria |
#286 (permalink) |
Thanks Ernest, for some reason I can not download the ones from Nuno...
over the weekend I will try to do some test with vray 1.5 demo and maybe with maxwell demo. Thanks!
#287 (permalink) | |
Have you looked at Indigo render engine? It's a WIP, but its free. |
#288 (permalink) |
Strange, here at home I can download nunos model but from work couldn't, firewall issues most likely.
I had followed for a while this site: http://homepages.paradise.net.nz/nickamy/ but had not know he had started "officially" his indigo render, very nice stuff. I think I ran into the original website when all the hype on maxwell had started and someone had suggested to look over at the indigo render (electronik render in the start) for the real sky-real sun lighting. But know it looks like it is picking up, nice. How about you, have you giving it a try? How about maxwell or the new real sky-sun in vray 1.5?
LinkBack to this Thread: http://www.cgarchitect.com/vb/4708-let-there-light-comparison-between-different-renderers.html
| Posted By | For | Type | Date | |
| CGTalk - realistic lighting in mental ray | Post #205 | Refback | October 19th, 2006 08:53 PM | |
