Originally Posted by plusarchi
i make an image of architecture: some object is block (i didn't made)
or
an image have many different views of the same building
is this images acceptable for qualification ???
Well all of us use pre-made models for some of our work, so I don't see that as a problem unless you did not model any of it.
As far as multiple views of the same building, like I said in an earlier post, unless the views of the building are significantly different it does not really show the range of skills you possess. You will get a better score for having 3 unique images that are really good than 3 images of the same building with the same lighting etc.
