Old July 16th, 2004   #1 (permalink)
Default Mental Ray memory error !!!
I really hope that someone here can help me out with the problem that I encountered using MentalRay.
I have created a scene (architectural -exterior) it has couple raytrace materials, skylight and a direct light .... nothing complicated .... using only Final Gathering (250) for rendering ...
When I render it at, let say 800x600 it takes about 3-4 mins to render .... no errors ... nothing - everything is totally fine ...
But when I raise it up to 4000x2800 it starts to render and then .... BOOM ... ERROR MESSAGE : MENTAL RAY HAS ENCOUNTERED A FATAL ERROR AND THE APPLICATION WILL NOW SHUTDOWN. tHE ERROR IS: MEM 0.9 031005:CANNOT FREE MEMORY.
and thats it ....
I can't do anything .... It is very frustrating to not being able to do anything about it ....
I also happened to own VIZ 2005 wich is pretty much identical to MAX (the rendering part). So I opened my scene there ... ....same thing ...
I checked in Preferences-> Rendering-> Bitmap Paging ... and I tried to raise all the parameters there ... but I don't think it helped because it crashed just the same way ...
anyway ... I really hope that somebody can help me !!!
PLEASE HELP !!! I'm frustrated to the level where you start to pull your hair out ....
akropol2000 is offline
Old July 16th, 2004   #2 (permalink)
izrut's Avatar
Bulgaria Send a message via ICQ to izrut
too much precalculation
U may try these actions as follow:
1.check the free space in your computer and the size of virtual memory
2.try to render same resolution but devide the siene in regions and then adjust them in ..for example photoshop.
3.reduce resolution
4.reduce the quality
5.connect to a farm...
6.buy a better machine...
) if none of these works...take a beer
cheers
izrut is offline
Huge Mental Ray Problem akropol2000 3ds Max 3 July 20th, 2004 12:02 AM
Memory error after 30 frames of animation in MR Gwilliam 3ds Max 2 July 1st, 2004 11:32 AM
3dsmax6 and mental ray lara 3ds Max 7 April 30th, 2004 03:27 AM
MentalRay 3.3 dleon Industry News 2 April 30th, 2004 01:46 AM
