Autodesk VIZ Autodesk VIZ
Old July 16th, 2004   #1 (permalink)
Chad Warner's Avatar
Default RPC Refelection problem
I'm not sure if other people have this problem or not, but whenever I have an RPC person set to reflect, they always render like they are a two-headed RPC person. Can someone please tell me that I am not the only one with this problem, and has an idea how to fix it?
Thanks,
Chad
Chad Warner is offline
Old August 9th, 2004   #2 (permalink)
Zortea's Avatar
Default Re: RPC Refelection problem
Iīve had the same problem, the solution...
a few retouch on Adobe Photoshop.
īcourse thatīs not the rigth way to solve the problems, but as long as I donīt know hou to solve this, I found that Phoshop do a grat job on this matter.
As far as I know, this only happens with the people RPC, the others are free from this problem.
It is not the need that makes a frog jump, itīs just a bad clutch...
Zortea is offline
tip: changing the color of RPC cars plastic Tips, Techniques and Frequently Asked Questions 33 September 24th, 2007 09:42 PM
RPC problem. Tommy L General Discussions 5 July 15th, 2004 07:59 AM
Problem with Archvision RPC shadows in max ross2280 3ds Max 5 March 15th, 2004 02:56 PM
RPC CAR RENDER PROBLEM Arquitetura3d 3ds Max 5 August 14th, 2003 11:59 AM
Problem with RPC plugin 3.2.6 -wolts- Autodesk VIZ 0 August 7th, 2003 01:18 AM
Đ Copyright 2001 – 2008 CGarchitect Digital Media Corp. All Rights Reserved.
