Go Back   CGarchitect.com > MISCELLANEOUS > 2D/3D Tutorials
2D/3D Tutorials Post links to architectural tutorials here. (ie. 3dsmax tutorials, lighting tutorials, modeling tutorials etc.)
Old July 27th, 2004   #1 (permalink)
joske's Avatar
Name: Philip De keersmaecker
Belgium
Default mental ray interior fast setup
Nakadate made a very fine setup in Brazil : http://www.cgarchitect.com/vb/6490-brazil-rio-global-photon-mapping-tutorial.html
nothing to add on my account, looks great, i never tried Brazil myself... i'm sure it's a great renderer, and also very fast.
However a lot of people seem to complain that mental ray is so slow and hard to master : well... let's do the same for the mental ray users then right?
pls note: this is not an attempt to find out wich renderer is 'the best, the fastest..." pls do not go into that peoples... plenty of those threads around allready so don't go that way ok? i'm sure all of the diff. solutions out their can do wonderfull stuff, and are very fast, so this is just a small test/proof that Mental Ray CAN be compared with the rest of them.
IMHO it looks very similar to the brazil version, no?
rendertime : 2 minutes on a pentium IV 2.8 gig 2Gddr
so compared to nakadate's Brazil version 5 min i would say mental ray can do the job fast.
see the max file attached
greetz,
phil
joske is offline
Old July 27th, 2004   #2 (permalink)
izrut's Avatar
Bulgaria Send a message via ICQ to izrut
Hi joske
nice example!I'm quite new in 3d field but I decadet to give a test with this siene. the wall of the origanaly posted by U siene were planes. I change them with boxes.render time has encreased by 1 sec.swithcing between the two images U can see a slight differece...I can't say which image U like more but next time U render have this in mind
p.s. this is not a critique to joske.His original idea is to give us all example for wat mr is caipable of.he is one of the people I owe my progress .
I just wanna help people achieve better results!
thank U
izrut is offline
Old July 27th, 2004   #3 (permalink)
joske's Avatar
Belgium
Default Re: mental ray interior fast setup
no problem izrut,
great to have somebody mentioning those small differences.
i only see a slight diff. in the way the photons are filtered and gathered in your results, this should be because in my setup the walls and floor are the same mesh and in the box-wall example each wall and the floor are seperate objects or meshes.
it seems obvious to me that the photons that are casted on two meshes might have a different bounce than on one and the same mesh all around... no?
that might also explain the slight in-/decrease in rendertime... mabey there are less or more photons bounced to calculate?? I'm just guessing here, this is an explanation that comes first to mind...
mabey someone should try a Vray and Final render setup with this scene? it might be very helpfull to see the 4 most used renderers next to each other...
joske is offline
Old July 27th, 2004   #4 (permalink)
izrut's Avatar
plane walls:
number of segments: 1x1x1
render time: 2min:11sec
number of segments: 50x50x50
render time: 3min:13sec
box walls:
boxes separated
render time: 2min:12sec
boxes attached
p.s. enough MR testing ... time for V-ray, Brasil and FR
izrut is offline
Old July 27th, 2004   #5 (permalink)
Glad you guys took a try at rendering the scene. A critique I have is the images from mr seem washed out and over-averaged--too little contrast. It is true the image at the end of the tutorial is a balance of a "decent" render in a short amount of time. It could be polished more with a few setting increases and a bit more render time. Anyway, good photon fun.
Cheers,
NN
Nick Nakadate is offline
Old July 28th, 2004   #6 (permalink)
joske's Avatar
Belgium
yes nakadate, i tried to make the comparison fair.
I even overdid the final gathering : the render didn't need that much of it, went for the 'silky smooth' look i guess
It was a very quick test to finally see what Mray was capable off speedwise
I'm sure if it really mattered that the render time could even go lower for similar results, but in all fairness : didn't really spent any extra testing on the settings for that kind of thing.
joske is offline
Old July 29th, 2004   #7 (permalink)
blaz's Avatar
Singapore Send a message via ICQ to blaz Send a message via MSN to blaz Send a message via Yahoo to blaz
done in FR stage1
renderign times 15 seconds, in dual xeon 2.8, with 2G ram
Beyond your Imagination
:: www.geocities.com/wimpy_l ::
blaz is offline
Old July 29th, 2004   #8 (permalink)
izrut's Avatar
ei blaz, very decent machine U've got
pls do render joske siene to tell us the time...
izrut is offline
Old July 29th, 2004   #9 (permalink)
** Edit - I read this thread the wrong way. I though you guys were looking for other R/S's to compaire the scene with. My bad, I've removed my posts.
Jeff **
pixelperfectg is offline
Old July 29th, 2004   #10 (permalink)
izrut's Avatar
***Edit - Nooooo...bring the post back .Just render the original siene too.
izrut is offline
Mental ray - matte replacement?! izrut 3ds Max 8 July 26th, 2004 01:49 AM
3dsmax6 and mental ray lara 3ds Max 7 April 30th, 2004 03:27 AM
MentalRay 3.3 dleon Industry News 2 April 30th, 2004 01:46 AM
To Mental Ray or not to Mental Ray?? mbr Autodesk VIZ 0 April 23rd, 2004 01:20 PM
