Name: John Pillai |
Hi,
I have to import .dxf from autocad. which is made in millimeters. WhenI import the shape i want to see the same measurement. Is there any particular scaling option? Becoz after importing, I never get same measurement even after changing units to mm. Thanks : |
Name: Alex Bicalho |
This is what you need to do to view all your units in Milimeters after import:
Set System Units = Inches Set Display Units = Milimeters Import and make sure Rescale Units is on Set the Units of your DXF in the dropdown Import All units should now match. Alexander |
| Anyone else model in AutoCAD? Anyone use file linking? | Reitveld | AutoCAD/AutoCAD Architecture | 44 | September 27th, 2008 05:59 PM |
| importing and uvw map applying autocad model in 3ds MAX | j.k | 3ds Max | 3 | May 13th, 2004 11:20 PM |
| Render in AutoCad | P.R.S. Sivakumar | General Discussions | 13 | September 11th, 2003 05:33 AM |
| Importing AutoCAD - MAX problems.... | Kassner | AutoCAD/AutoCAD Architecture | 5 | May 5th, 2003 06:53 AM |
| Importing 3DS files to AutoCAD? | Matt4 | AutoCAD/AutoCAD Architecture | 4 | March 28th, 2003 07:48 AM |
