3ds Max Autodesk 3ds Max
Old August 3rd, 2004   #1 (permalink)
Default Opacity
Can anyone tell me why when I apply a tree material to a flat plane, and apply an opacity map to the opacity channel, when I then render using Mental Ray there is a brighter area around the tree where there should be nothing.
See attached image.
aflack is offline
Old August 3rd, 2004   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Opacity
switch off all specular/shiney properties of the material
STRAT is offline
Old August 3rd, 2004   #3 (permalink)
jysngltndz's Avatar
Name: jayson giltendez
Philippines
Default Re: Opacity
yup glossiness and speculars, try removing it...what shadow type are you using? as i know raytraced shadow works well with opacity. just try it with mr.
jysngltndz is offline
Old August 3rd, 2004   #4 (permalink)
Default Re: Opacity
I guess I must be doing something wrong, I have taken all the specular and gloo off the material. Also I am using Ray trace shadows.
Have a look at my material settings below.
Thanks for yoru patience.
aflack is offline
Old August 3rd, 2004   #5 (permalink)
wda
wda's Avatar
Name: William Alexander
Default Re: Opacity
aflack,
Two things to consider
1. is your mask absolute 000 & 255 (black white), adjust that map in the Materials>output>colormap to see if that eliminates the problem or check in PS
2. Environment effects such as fog always brighten the 'opaque' or masked part of an object, turn it off if using
rgrds
WDA
e-p.s. thats some funny looking 'frosted glass' LOL
wda is offline
Old August 3rd, 2004   #6 (permalink)
jucaro's Avatar
Name: Juan Carlos Rosalejos
Philippines  Send a message via Yahoo to jucaro
Default Re: Opacity
Check enable PROCESS BACKGROUND AND ENVIRONMENT MAPS in your exposure control found in the environment tab of your environment and effects dialogue.
MD8 Design Solutions
X3MFX Interactive Design Agency
DE MAX Design PTE LTD
jucaro is offline
Old August 4th, 2004   #7 (permalink)
kicks's Avatar
Name: patrick deno desamparado
Philippines
Default Re: Opacity
<if you are using sphere containing your scene, just apply 100% transparent material to it (standard mat'l. opacity=0). hope this helps
kicks
IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER.
kicks is offline
Old August 25th, 2004   #8 (permalink)
Default Re: Opacity
Thanks for all your help, I ended up placing the tress in Photoshop but in my new image I want the trees to reflect in the glass.
I tried what Jucaro suggested and it does get rid of the glow round the trees but it blows out the background image as well.
There must be a way around this if you want to use an background image thats also my environment map?
Please see the attached images for what I mean!
aflack is offline
Old August 25th, 2004   #9 (permalink)
Name: Herminio Jalocon Jr.
Philippines  Send a message via Yahoo to noi-pi
Default Re: Opacity
Thats exactly what happen to my opacity maps if i didnt check process env maps. It works but what happen was just like that! Overblown env background. From then on I shy away with Exposure Control. Besides I don't want to add another settings aside from Render Dialog box.
We manufacture modern antique furniture.
noi-pi is offline
Old August 25th, 2004   #10 (permalink)
Default Re: Opacity
So is there no way you can get around this then?
aflack is offline
How to reflect opacity? M_Jaco Autodesk VIZ 2 July 23rd, 2004 01:24 PM
OPACITY ON VRML radioVOY General Discussions 7 June 21st, 2004 03:14 AM
Glass opacity Tommy L Autodesk VIZ 6 March 29th, 2004 11:37 AM
how to use an opacity map on a raytrace material? salf Autodesk VIZ 2 December 16th, 2003 10:45 PM
Opacity Maps and Volume Light Gander0 General Discussions 0 September 24th, 2003 11:37 AM
