Go Back   CGarchitect.com > 3D SOFTWARE > finalRender
finalRender cebas finalRender
Old August 17th, 2004   #1 (permalink)
Maxer's Avatar
Default Final Render animation problem
Has anyone run across a problem when network rendering an animation with Final Render with different computers rendering a different GI solution? I'm doing some tests and if I'm using 5 machines each one will render out a different looking GI solution even though I'm re-using the solution.
Maxer is offline
Old August 17th, 2004   #2 (permalink)
Name: Tom Hamelrijckx
Belgium
Default Re: Final Render animation problem
I have had similar experiences, though not with animations. Starting rendering in a dark part of the image gives another solution than start rendering the exact same situation in a light part. What happens if you render the animation on the same machine? (one frame after the other)
Mazinger is offline
Old August 17th, 2004   #3 (permalink)
Maxer's Avatar
I'll check it out and let you know.
Maxer is offline
Old August 17th, 2004   #4 (permalink)
Do you have the same core installed? Pent III or Pent 4 on all the machines. as well are you using DR for rendering?
Mike
mtutaj is offline
Old August 17th, 2004   #5 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
project looks interesting. post it in the completed work when you are done. i would like to see it.
travis schmiesing
crazy homeless guy is offline
Old August 17th, 2004   #6 (permalink)
Maxer's Avatar
The core is the same on all of the machines, but I've been using network rendering from Max. I was under the impression that DR was only for single images, is that wrong?
As for the project it's not mine, it's not even a project, it's just a scene from a tutorial that I've been working on and experimenting with.
Maxer is offline
Old August 18th, 2004   #7 (permalink)
Maxer's Avatar
I've run some tests and it seams that when I render the animation on a single computer it comes out fine. When I start using more than one computer that's when I start getting the flickering problem. What would cause this?
Maxer is offline
Old August 18th, 2004   #8 (permalink)
you need to reuse your lighting solution
Mike
mtutaj is offline
Old August 18th, 2004   #9 (permalink)
Maxer's Avatar
Eureka! I finally got it to work, I had to check "save solution, reuse solution, and lock solution". Thanks for all the help!
Maxer is offline
Final Render Speed Maxer finalRender 11 August 1st, 2004 08:27 AM
flickering in final render blaz finalRender 8 July 21st, 2004 08:26 PM
Viz4 Animation Jitter/Flicker Problem jbennett134 Autodesk VIZ 6 March 25th, 2004 09:39 AM
Christmas Gift : Final Render Stage-1 Evaluation + Tutorials muzzy 3ds Max 8 January 7th, 2004 09:32 AM
help needed from final render experts yosa_b Work in Progress (WIP) 4 November 17th, 2003 10:51 PM
