Name: Alex Bicalho |
Tile (also known as Bricks) is a mathematical noise function. You found a limitation in the function that causes this artifact.
What's happening here is that your Gap is larger than the tile, causing the math loop. Make the gap = 0,1 and that should solve your problem. Hope it helps, Alexander |
| Computer Problem? Need Help? Check Here First! | Greg Hess | Hardware and Technical Discusions | 7 | August 22nd, 2008 05:38 PM |
| I'm having a problem | omar | General Discussions | 7 | June 10th, 2004 09:36 AM |
| Viz4 Animation Jitter/Flicker Problem | jbennett134 | Autodesk VIZ | 6 | March 25th, 2004 09:39 AM |
| Video Card problem? | Jeff's Friend | Hardware and Technical Discusions | 12 | September 11th, 2003 05:33 AM |
| Anyone know a good technique for roof tiles? | Erik Lund | 3ds Max | 7 | November 8th, 2002 08:48 AM |
