Autodesk VIZ Autodesk VIZ
Old September 8th, 2004   #1 (permalink)
Default Material Reflectance Values For Radiosity
Hi all!
Does anybody know of somewhere a comprehensive list of material reflectance values can be obtained as a guide / reference for creating materials when using radiosity?
I have found the basic overview of values in the help files which come with viz and max but feel they are a very rough guide. As a relatively inexperienced radiosity user i feel i have developed a good overview of the concepts and areas to pay attention to, but am now lacking the details of these elements which will make a great difference to the quality of images i'm can produce.
Thanks, James
JamesTaylor is offline
Old September 8th, 2004   #2 (permalink)
tcorbett's Avatar
Default Re: Material Reflectance Values For Radiosity
Honestly, I've found the types of architectural materials in VIZ 5 to be good in most cases, though occasionally I will turn down the color bleed or reflectance in the advanced lighting override rollout, if there is too much.
tcorbett is offline
Old September 8th, 2004   #3 (permalink)
Hi Tom.
Unfortunately i'm using Viz 4 so don't have the architectural material type available for use. I have come across them before in max 6 but would also like to make a set of materials from scratch that i know are suitable for continual use.
I'm also on a step learning curve at the moment and i feel that such information as reflectance values could be of great benefit as reference and a way of checking that one of the many elements which effect the radiosity solutions are correct.
Thanks James.
Old September 8th, 2004   #4 (permalink)
Fran's Avatar
Name: Frances Gainer Davey
Hi James,
This will help you a lot (see Dave Buchhofer's replies):
http://www.cgarchitect.com/vb/showth...ht=reflectance
- Fran
Fran is offline
Assigning Material in VIZ5 Wampa Autodesk VIZ 4 May 24th, 2004 01:02 AM
reflectance proces2 3ds Max 3 July 3rd, 2003 02:52 PM
Material reflectance? purnomo_adi Autodesk VIZ 1 January 2nd, 2003 05:15 AM
Material Script nisus Scripts 5 July 8th, 2002 11:49 PM
