hi There
Andy
i use autocad, VIZ and FotoChop everyday for arch vizualisation
check This out
http://usa.autodesk.com/adsk/servlet...3112&preview=1
Autodesk Revit Building
Autodesk VIZ 2005 Interoperability Plug-in
With Autodesk VIZ® 2005 interoperability plug-in, import DWG files produced in Autodesk Revit Building and use them to create stunning, photorealistic interior and exterior renderings.
White Papers are located at
http://usa.autodesk.com/adsk/servlet...112&id=3782406
Autodesk Revit: Implementation in Practice(zip - 1842 Kb)
Autodesk Revit ROI White Paper and Calculator
Want to know if a technology investment is really worth it? Understanding the financial concept of return on investment, or ROI, is the first step. Using real-world productivity data from a survey of Autodesk® Revit® users as an example, this white paper explains exactly what ROI means and how to compute it. An interactive ROI worksheet is included.
Autodesk Revit ROI White Paper and Calculator(zip - 208 Kb)
Download more white papers by clicking the links below.
Autodesk Revit Building for AutoCAD Users(pdf - 56 Kb)
Multi-user Collaboration with Autodesk Revit Worksharing(pdf - 103 Kb)
Autodesk Revit Interoperability w/ CAD(pdf - 371 Kb)
Viewing a PDF file requires
Adobe® Reader®, available at no charge from the Adobe website.
Related Information
from FAQ page
http://usa.autodesk.com/adsk/servlet...112&id=5106381
Following are a few of the new features:
- Enhancements to Autodesk Revit Parametric Components: Use the Edit Loaded Families feature to edit previously loaded families in Autodesk Revit Building. Use Scheduling Nested Families to schedule the components in a nested family.
- Interference Check: Set parameters to scan your model for problems with conflicting elements.
- Publish to Autodesk Buzzsaw: Easily upload your files from Autodesk Revit Building to your Autodesk® Buzzsaw® project site. Automatically convert Autodesk Revit Building files to either DWG or Autodesk® DWF™ (Design Web Format™) file format. Use default template assignments to assign properties to a view and set those properties back to their original state before publishing or printing a project.
we dont have Revit yet but are planning on getting sometime (soon) in the office
personally i started out with Accurender (well after 3ds dos) but went to VIZ as soon as i could get my hands on it
i hope This helps
Randy
