Old April 13th, 2005   #8 (permalink)
vizwhiz
vizwhiz's Avatar
Default Re: What render package to pick?
hi There
Andy
i am somewhat confused, which VIZRender are you using??
you said:
I have just got hold of a copy of 3DViz render R3
is That VIZ r3 (no file-linking) or VIZRender r3 (the ADT version)??
i guess i am still doing it the "old-fashioned" way
i model everything in bare-bones autocad using 3d solids
Then file-link into VIZ 4 (or newer) = not intelligently linked
the file-link in VIZ 4 will (always) corrupt sooner Than Later
i use VIZ2005 at work VIZ 4 at home, its a big difference
and so far VIZ2005 has not corrupted a file-link yet. so far so good
some of my acad files add up to over 200 mbs linked into a VIZ project
and it is only the 1st phase of a 220 acre project that is under re-design
Revit is the wave of The Future, model once use many
somewhat like archicad in that all changes appear everywhere
consistently, always current
you can export to autocad to do details, but Revit people say That is not necessary, That you can use Revit ONLY
if you figure This out, pls let me know how it works
hope This helps
i am going to be checking into Revit more, as soon as possible
Randy
vizwhiz is offline   Reply With Quote
