3ds Max Autodesk 3ds Max
Old September 16th, 2004   #1 (permalink)
Default importing a cad dwg to 3d max 4
hi there, i'm trying to import a cad dwg file into max 4 layers checked and no error message appears,however nothing shows in my viewports and nothing appears in the select list.
any ideas- do i have to import to illustrator then out to max?
(haven't tried yet cause i only have photoshop).
thanks
james
grooveulas is offline
Old September 16th, 2004   #2 (permalink)
bully712's Avatar
Default Re: importing a cad dwg to 3d max 4
What version of CAD are you using? I was having a similar problem with ADT 2004 and VIZ 4
bully712 is offline
Old September 16th, 2004   #3 (permalink)
hi there marc
not sure what ver. the cad is -as i just received it from the architect.
i'll find out...
thanks
j
Old September 17th, 2004   #4 (permalink)
hi marc the version is 2004
thanks
Old September 17th, 2004   #5 (permalink)
bully712's Avatar
James,
You should read this Thread. I had the same problem with exporting PLines into Viz4 from ADT 2004. I eneded up reinstalling Autocad 2000, until I get the upgrade to Viz 2005.
http://www.cgarchitect.com/vb/7079-exporting-plines-viz4-problem.html
bully712 is offline
Old September 18th, 2004   #6 (permalink)
oyie's Avatar
Philippines
hi, try saving the file to 2000 format before importing it to 3dsmax
oyie is offline
Old September 19th, 2004   #7 (permalink)
ipdesigner's Avatar
Philippines  Send a message via Yahoo to ipdesigner
*i second the motion, try using Autocad 200, Architectural Desktop 2i..
*it doesnt really work for Autocad 2004...classic is better
ipdesigner is offline
3DS Max or Autocad Sergio 3ds Max 21 October 1st, 2007 09:18 PM
More CAD tools? parallel line, spline dwg import, tip PellePixel 3ds Max 1 July 8th, 2004 01:41 AM
rendering dwg windows in max fatNjazzy 3ds Max 8 June 26th, 2004 04:21 AM
cad to max monkeyboy 3ds Max 3 November 16th, 2003 04:15 AM
3d CAD v Max beowulf General Discussions 12 July 21st, 2003 11:35 PM
