3ds Max Autodesk 3ds Max
Old September 21st, 2004   #1 (permalink)
India  Send a message via Yahoo to virses
Default mapping gizmo transformation !!??
is it possible to transform the mapping gizmo (uvw map) with help of modifiers like bend etc?. for example, i made a box and applied the box mapping. now if i apply the bend modifier, mapping also bends. I want to do same to the mapping gizmo without affecting the geometry. any ideas if it doesn't sound bizzarre !??
virses is offline
Old September 21st, 2004   #2 (permalink)
Sweden
Default Re: mapping gizmo transformation !!??
hmm... not sure about this...
dont think you can apply a modifier directily to a mapping-gizmo. (atleast not in max 4.2 which I use).
But maybe you can make temporary object, apply the uvw-map-gizmo of choice, apply a bend modifier to the object. Then select your actual model, and aquire the uvw-map from the first temp-object. ? Dont know if this will work but, if your lucky the "bent" uvw-map will transfer to your model.
there was a plugin for MAX a couple of years ago, that did all sorts of things with uvw-gizmos... dont remember what it was called, but If I find out Ill post a link.
skogskalle is offline
Where is that Gizmo ? Bewdy General Discussions 3 August 3rd, 2004 07:39 AM
issues with mapping. salf 3ds Max 1 May 30th, 2004 03:02 PM
roof tile mapping brehaut Cinema 4D 4 April 26th, 2004 09:39 AM
Edit Mesh and Material Mapping Eric Autodesk VIZ 1 May 2nd, 2003 10:08 AM
noise mapping on mirrored objects proces2 Autodesk VIZ 4 April 14th, 2003 05:17 AM
