3ds Max Autodesk 3ds Max
Old September 23rd, 2004   #1 (permalink)
Rick Eloy's Avatar
Default UI and Default Switcher: can I customize it?
Hey, folks!
I was wondering here... is there a way to create or customize our own default? Like this: when you select DesignViz, Max automatically sets all the materials to Architectural, right? Can we have a "Default" where all materials come, let's say, VRay Materials or finalRender or whatever? That would save a lot of time. Anyone?
Rick Eloy
Rick Eloy is offline
Old September 23rd, 2004   #2 (permalink)
Chad Warner's Avatar
Default Re: UI and Default Switcher: can I customize it?
If wondered this myself---that would help a lot. The closest Iv'e come is to setup all of my materials in the editor, and then save that set as the 3dviz.mat. That way, when I choose to get material from library, those are the ones that come up.
-Chad
Chad Warner is offline
Old September 23rd, 2004   #3 (permalink)
Rick Eloy's Avatar
That's what I've been doing, but it would be no much nicer if we could create our own default......
Rick Eloy
Old September 23rd, 2004   #4 (permalink)
abicalho's Avatar
Your defaults folder has a couple folders in it. Clone one of these folders with all the files. Now rename them, customize them, etc.
Once you do that, you will be able to specify that as your default in one of two ways:
- Custom UI Switcher
- Configure Paths > Defaults > specify the new defaults path
The Custom UI Switcher does nothing more than provide you a nice UI for the 2nd option.
Hope this helps,
-alexander
abicalho is offline
Old September 23rd, 2004   #5 (permalink)
Rick Eloy's Avatar
Thank you so much, Alex! Works like a charm!
Rick Eloy
