3ds Max Autodesk 3ds Max
Old September 29th, 2004   #1 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Default MR: interior or exterior
Hi all,
When making an interior rendering with a view on the exterior (terraces, environment,...) do you use interior or exterior for the exposure control?
Basicly I got a dark interior when finetuning a good exterior, or an burned out exterior when making a good interior...
What strategy do you use? Any more tips?
rgds
nisus
nisus is offline
Old September 29th, 2004   #2 (permalink)
kicks's Avatar
Name: patrick deno desamparado
Philippines
Default Re: MR: interior or exterior
<funny but I do not use at all exposure control be it interior or exterior.(except for that one scene used for the unchallege..) maybe because I don't use sunlight system nor ies sun & sky.
kicks
IF YOU DIM YOUR LIGHT SO THAT OTHERS MAY SHINE, THE WHOLE WORLD GETS DARKER.
kicks is offline
Old September 29th, 2004   #3 (permalink)
wda
wda's Avatar
Name: William Alexander
Approach-
It's like taking pictures with a camera, can't use the same settings inside and out with out compromise.
The exposure control has become a means of last resort , for me anyway. It really kills quite a bit of depth if not used just for fine adjustments.
Although it can be cheated.....to some degree anyway
Get the blown out area's materials to a lower reflectance level, leaning toward higher saturation.
Using standard materials (when needed) & oren-nayer-blinn shader, the roughness adjustment really gives some good control over diffuse levels allowing the darkening of over bright materials. Seems to keep the saturation up vs. washing it out with the actual Diffuse Slot adjustment.
On the same thinking locking the ambient-diffuse-specular colors and lowering the specular level will help the blow outs also.
Then there's always compositing
Cheers
WDA
wda is offline
Old September 30th, 2004   #4 (permalink)
nisus's Avatar
Belgium
well, honestly... I've been explaining this to my collegue for over two years now, but he won't listen... I understand why, he wants a result where both inside and outside are balanced... It's clear that this is a good goal... Unfortunately there are some issues between dream and reality...
rgds
nisus
nisus is offline
Old September 30th, 2004   #5 (permalink)
joske's Avatar
Name: Philip De keersmaecker
Belgium
just tell him to try it with a real photo camera in a real room/terras with lots of sun outside... if he can do that ... pls let him explain how he managed to do that... :b
joske is offline
Old September 30th, 2004   #6 (permalink)
nisus's Avatar
Belgium
I did...
anyway... I do understand his point... it WOULD be great!
nisus
nisus is offline
Old October 12th, 2004   #7 (permalink)
pseudoe's Avatar
Originally Posted by nisus
Hi all,
rgds
nisus
Hello,
I'm new to the forum and saw your question- I've spent a bit of time looking into ways to get more of a 'human eye' exposure, and the closest I've seen so far is made with this product:
http://www.hdrsoft.com/index.html
It's a process called tone mapping that that takes a series of exposures and averages them using various fascinating math stuffs.
e.
pseudoe is offline
Old October 13th, 2004   #8 (permalink)
why not trying to render the interior and exterior seperatly, the composite the shots in After Effects. That way you can control both elements independently.
bwilson is offline
Old October 14th, 2004   #9 (permalink)
nisus's Avatar
Belgium
Hi bwilson,
That's what we do for now, but it would be great to render only one pass...
rgds
nisus
nisus is offline
Old September 22nd, 2005   #10 (permalink)
nisus's Avatar
Belgium
So anyone more thoughts on this in the main time?
nisus
nisus is offline
