3ds Max Autodesk 3ds Max
Old October 7th, 2004   #1 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Default MR: blurred reflections
Hi,
How can I make blurred reflections in MR without using the metal shader?
Basicly, I can make reflections the way I want with the MR-mental shader, but I don't get the highlight areas when light an shadows strike the surface...
I've tried to mix metal and DGS shaders, but the DGS reflections always shine through. I've also added a DGS material in the metal/diffus color slot... Both don't give me the disired result... Any tips?
OR How can I make blurred reflections with the DGS shader?
rgds
nisus
nisus is offline
Old October 8th, 2004   #2 (permalink)
nisus's Avatar
Belgium
Default Re: MR: blurred reflections
No One?
nisus
nisus is offline
Old October 19th, 2004   #3 (permalink)
nisus,
I was asking myself the very same question earlier. If you have not found an answer, please check out the thread over on CGTalk where I got my answer. In short, it involves using a Metal(Lume) material in a mix with your floor, and using falloff as the mix map.
Here's the link to the thread that helped me out:
http://www.cgtalk.com/showthread.php...page=103&pp=15
It's post #1544, (you have to scroll down a bit) with the images showing a red box on a wood floor. The next reply is from Jeff Patton, who is a Mental Ray material Guru, and he's got a file there that solve the problem as best we know how.
Good luck.
jayson is offline
Old October 19th, 2004   #4 (permalink)
nisus's Avatar
Belgium
Hi Jason,
Exactly what I was looking for! I have tried to do the same with nested metal/dgs shaders, but did not come that close to Jeff Pattons result.
Tnx also for the very clear guiding: link, number of post ,-) It took me only seconds to find what you ment, something that not everyone is aware of when posting tips ,-)
rgds
nisus
nisus is offline
environment reflections fi3er Autodesk VIZ 2 September 12th, 2004 07:26 AM
blurry reflections tip STRAT Cinema 4D 10 April 27th, 2004 09:38 AM
Blurred reflection in stand alone Lightscape andrius Lightscape 2 March 19th, 2003 04:14 AM
blurred reflections proces2 Autodesk VIZ 5 November 20th, 2002 08:08 PM
Reflections ????? STRAT Cinema 4D 1 May 21st, 2002 05:33 AM
