3ds Max Autodesk 3ds Max
Old October 7th, 2004   #1 (permalink)
mbr
mbr's Avatar
Default Missing Maps on Merge
I've got one file that I am trying to merge 5 others into. 3 work, the maps show in the viewport and render properly, but the other two only show the maps in the viewport, and when I render, they show up with a dark gray material where the maps should be.
These files render properly before the merge and I am sure that the path is there for the bitmaps.
Any ideas? There are far too many maps to reapply.
Thanks.
mbr is offline
Old October 8th, 2004   #2 (permalink)
quizzy's Avatar
Default Re: Missing Maps on Merge
It could be a memory problem. Too many bitmaps? What you could try is to Resource Collect the files first to one directory, and merge them from there.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old October 8th, 2004   #3 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
Do you use xrefs? if so, open the xrefs and do a resource collect from them too...
rgds
nisus
nisus is offline
material maps for SketchUp mmolina SketchUp 4 September 28th, 2004 11:50 AM
Missing DLL Dialog Box Arkitec Autodesk VIZ 4 July 15th, 2004 02:05 PM
Text window missing !! fred_bock AutoCAD/AutoCAD Architecture 2 July 3rd, 2004 04:33 AM
missing camera correction feature gail 3ds Max 4 June 3rd, 2004 12:05 PM
grrrrr!! maps not displaying?! Gen. Disorder Autodesk VIZ 4 September 23rd, 2002 01:08 AM
