3ds Max Autodesk 3ds Max
Old November 2nd, 2004   #1 (permalink)
Default Removing missing XREF Objects
Is there an efficient way of removing missing XREF Objects from a scene? I updated an XREF Object file (that is later duplicated numerious times in another scene) removing some of the geometry. Now when I rendering the file containing the XREF Objects I get a missing XREF Objects dialog.
Is it possible to purge only the missing XREF Objects from the XREF scene without having to XREF and rearray?
bwilson is offline
Hiding Objects in C4D manepalli Cinema 4D 2 November 26th, 2004 10:12 PM
"Xref object" won't recognize new geometry after I xref object RTurner Autodesk VIZ 0 August 26th, 2004 12:19 PM
Viewing objects during arc/rotate/move DeeSee Autodesk VIZ 1 August 24th, 2004 05:45 PM
missing camera correction feature gail 3ds Max 4 June 3rd, 2004 12:05 PM
AEC Objects - Help needed Urgently steven martin Autodesk VIZ 2 August 15th, 2003 03:51 PM
