Go Back   CGarchitect.com > 3D SOFTWARE > finalRender
finalRender cebas finalRender
Old November 10th, 2004   #1 (permalink)
alex3d's Avatar
Default final render and RPC
i'm trying to render a video using final render as render engine, i have two compuiters in the network, final render has its own server service, its detect automaticly all computers. cool. to share maps and textures to render it has a special feature named distribuited maps, you check it and the server give to the slaves computers all that it needs to go on its work. well it looks like final render does'nt send any info about rpc objects to slaves computers, so you will have a blak spot in the zones that slaves computers are rendering.
anyone with he same problem?
alex3d
_________________
work, play and keep your mouth close.
Albert Einstein
alex3d is offline
Old November 10th, 2004   #2 (permalink)
Maxer's Avatar
Default Re: final render and RPC
I have all of my RPC's located on a server that all my slaves can see. It does take a little longer to load the RPC's but I haven't had any problems with RPC's missing. You can also use the netrender feature in Max to render out the video, if you use this you can include all the maps in the package that Max creates.
Maxer is offline
Old November 10th, 2004   #3 (permalink)
quizzy's Avatar
if you include maps in the backburner of MAX it also copies the RPC textures. And some of them are really big, so a lot of traffic. So what I also do is to put all my RPC on a network drive that all of my slaves can see...
Another thing, somehow the RPC textures need to be in a path that is defined in the plugin path ini file.
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old November 11th, 2004   #4 (permalink)
alex3d's Avatar
Red face Re: final render and RPC
thanks everybody, i will set up all this night.
alex3d is offline
RPC Help! (network rendering) wil General Discussions 4 October 27th, 2004 10:49 PM
RPC Refelection problem Chad Warner Autodesk VIZ 1 August 9th, 2004 07:27 AM
rpc problems..sorry for wrong posting earlier haneet khanna 3ds Max 3 May 30th, 2004 06:59 AM
rpc problems haneet khanna 3ds Max 1 May 9th, 2004 08:54 AM
RPC CAR RENDER PROBLEM Arquitetura3d 3ds Max 5 August 14th, 2003 10:59 AM
